Signalling Mirror
Submitted: Thursday, Jul 19, 2007 at 09:08
ThreadID: 47870 Views:2720 Replies:6 FollowUps:10
Does anyone know where iI can get hold of a double sided mirror eg stainless steel with the reflective sighting hole.
Ian
Reply By: DIO - Thursday, Jul 19, 2007 at 09:33
Let Google 'be your friend' - in the meantime have a look at this Link
AnswerID: 253314
Follow Up By: Member - Ian F (WA) - Thursday, Jul 19, 2007 at 09:38
Thanks for the info. DIO
Ian
FollowupID: 514405
Reply By: Jugs - Thursday, Jul 19, 2007 at 09:42
Most good camping stores have them
AnswerID: 253315
Reply By: Smudger - Thursday, Jul 19, 2007 at 10:43
Why not use a DVD disc?
AnswerID: 253321
Follow Up By: Member - andrew B (Kununurra) - Thursday, Jul 19, 2007 at 10:59
up here for thinking eh - good sugestion!
FollowupID: 514414
Follow Up By: equinox - Thursday, Jul 19, 2007 at 12:00
A DVD (or normal grooming mirror) will not have the special targeting features that a true heliograph (signal mirror) has.
FollowupID: 514422
Follow Up By: hoyks - Thursday, Jul 19, 2007 at 18:54
Every DVD/CD I have seen has a hole fitted ;-).
Just hold the mirror/CD over your eye, place your thumb over the target at arms length then flash the reflected light at your thumb.
Easy as.
FollowupID: 514480
Reply By: Shaker - Thursday, Jul 19, 2007 at 11:19
Almost any marine chandlery, eg: Whitworths.
AnswerID: 253325
Follow Up By: Mr Fawlty - Thursday, Jul 19, 2007 at 14:50
Absolutlery Shaker, but be prepared to pay a premium for it. Why not buy some international signal flags???
I saw one of these for sale at an "Outdoors" shop (mountain designs), $38 in a smart pouch....
Personally I'll go back to semaphore signaling or a stolen smoke grenade would also give your position away.
FollowupID: 514432
Follow Up By: Shaker - Thursday, Jul 19, 2007 at 15:13
Yes, you're probably right, not too many here could afford $4.50, or especially the dearest one at $9.95 ..... Site Link
Just as a matter of interest, you may like to know that you are living in the past, Semaphore, along with Morse Code is history, & no longer officially recognised!
Carrying orange smoke flares would be a very good idea along with a heliograph (signal mirror), if you are going well off the beaten track.
FollowupID: 514436
Follow Up By: jdbb - Thursday, Jul 19, 2007 at 18:38
I've got a piece of stainless steel mirror about 3"x2". Haven't bothered with any holes in it. Just hold the mirror near my face, extend other arm, sight through the bottom corner of the mirror and my thumb on the extended arm, get the sun reflection from the same corner to just hit my thumb and thats it.
Came in very handy a few years ago, miles out to sea, engine out, no mobile, no battery so no radio. Managed to signal an ab diver on his boat a few miles away. Never go without it.
jd
FollowupID: 514471
Follow Up By: John R (NSW) - Tuesday, Jul 24, 2007 at 20:32
Actually Shaker, Morse is far from dead in the aviation industry. In fact, all ground-based navigation aids are primarily identified by Morse Code worldwide :-)
It's also widely used with Navies for light signals between ships at sea.
We carry heliographs in our survival kits and life raft packs. Amazingly effective piece of kit for something so simple. Hope I never have to use one but!
FollowupID: 515341
Follow Up By: Shaker - Tuesday, Jul 24, 2007 at 23:44
John R (NSW) .... I may have been misinformed & have to stand corrected re Morse Code, I know Semaphore is no longer used & I was led believe that same was true about Morse Code, although I thought that I read that radio operators no longer had to have an understanding of it.
FollowupID: 515382
Follow Up By: John R (NSW) - Wednesday, Jul 25, 2007 at 07:50
Gidday Shaker,
When I did my Instrument rating back in the '80s I had to pass a test of 10 WPM (receiving) Morse (to ident the navaids mentioned above). In the '90s this was removed because CASA probably figured that pilots could read a chart and get the Morse off it.....
I'm not sure about Amateur Radio Licences 'coz I don't hold one. I think they are somewhat more difficult to get than a Flight Radio Operator's.
With the advent of Flight Management Systems there is now more emphasis on the GPS component (with its inherent limitations, etc from a flight navigation point of view).
FollowupID: 515392
Reply By: Member - Mike DID - Saturday, Jul 21, 2007 at 22:51
Any mirror with a hole in it will work (or a CD).
Look through the hole at the target and hold your finger in front of the target. Move the mirror so the sun's reflection hits your finger - tested it two months ago with an aircraft at 1000 feet.
AnswerID: 253766
Reply By: Member - Vincent A M (NSW) - Tuesday, Jul 24, 2007 at 18:51
send me your address & I will send you one have heaps of them from old life-rafts I have condemned of the years
AnswerID: 254262
