Fuel economy and maths
Submitted: Sunday, Jul 22, 2007 at 08:07
ThreadID: 47963 Views:7260 Replies:7 FollowUps:12
Morning all
I'm afraid I'm mathematically challenged, so could someone explain to me the formula for working out litres/100km, what requires dividing or multiplying by what? I did manage to work it out once, but can't remember what I did.
Many thanks
Jon
Reply By: Col_and_Jan - Sunday, Jul 22, 2007 at 08:18
An example: If you used 46 lt to travel 553 km.
Divide 46 by 5.53 (the number of 100 km stages) giving 8.3 lt per 100 km
Calculators help.
Col
AnswerID: 253793
Follow Up By: Nick R (VIC) - Sunday, Jul 22, 2007 at 09:59
Or a little more simply (litres used/distance travelled)x100 (46/533)x100=8.31826401 litres per 100km
NickR
Carpe Cerevisi
FollowupID: 514872
Follow Up By: Member - Andrew (QLD) - Sunday, Jul 22, 2007 at 10:39
Nah, i like Col and Jans concept as it is somewhat easier to divide out in the field without calculators etc and get a rough answer. :-)
Either one will work though... ;-)
FollowupID: 514874
Follow Up By: Member - Raymond S (QLD) - Sunday, Jul 22, 2007 at 19:50
Found the correct site to down load the fuel calculation.
go to Google & type in,
Caravan & Camping South Australia,
select feeling lucky,
when the site comes up click on Hints & Tips,
when hints & tips page is up click on Fuel Consumption,
on the next screen you will be able to download the pdf which will give you the chart.
Sorry for the inconvienence I had my wires crossed as to where I originally sourced this from.
Regards Ray
FollowupID: 514974
Reply By: Member - Raymond S (QLD) - Sunday, Jul 22, 2007 at 08:27
Morning jon p, if u go to the Caravan & Camping site u will be able to down load a Fuel consumption chart. This chart has a conversion of ltrs per hundred klm makes life easy.
Regards Ray
AnswerID: 253795
Follow Up By: Member - Raymond S (QLD) - Sunday, Jul 22, 2007 at 08:32
Sorry jon p, I should have said www.caravanandmotorhome.com.au
Regards Ray
FollowupID: 514863
Follow Up By: Member - Crazy Dog (QLD) - Sunday, Jul 22, 2007 at 09:38
Couldn't find it Ray..
Grrr!!!
FollowupID: 514870
Reply By: Mike Harding - Sunday, Jul 22, 2007 at 08:27
This fuel consumption calculator may be useful too:
" target="EOF" class="lbg">www.csgnetwork.com/gaskpl.html
Mike Harding
AnswerID: 253796
Reply By: DaveO*ST-R - Sunday, Jul 22, 2007 at 08:32
Jon,
One of many calculators you can find.
Site Link
As to calculating it manually, for an example, if you have travelled 425 km and used 73 litres - divide your km by 100 (425 km divided by 100 = 4.25) Then divide your litres used (73) by 4.25 and your answer is 14.6 l/100km. The simple way is to use the calculator in the link !
AnswerID: 253800
Follow Up By: jon p qld - Sunday, Jul 22, 2007 at 11:00
Thank you all very much for your replies and the links, it's quite simple to work out once you know how.
Once again many thanks
Jon
FollowupID: 514878
Follow Up By: bigmark - Sunday, Jul 22, 2007 at 11:02
And if you got that fuel consumption you could get rid of the vehicle.!!
FollowupID: 514879
Reply By: Pezza (Bris) - Sunday, Jul 22, 2007 at 11:42
The other way is to divide your Km travelled, 650, by the litres used, 54, which gives you 12 km/lt.
I find this much easier when doing a trip, set trip meter once full, then divide the km on the trip meter by the litres you put in the car when you fill up, this way it's easy to work out how many km you can travel with the amont of fuel you have with you. ie. to travel 650 km you divide 650 by 12 = 54lt, so if you need to travel 650 k's between fuel stops you know you will need 54 ltrs plus a safety margin to do it.
Avagoodn
Pezza
AnswerID: 253824
Follow Up By: Member - Duncs - Sunday, Jul 22, 2007 at 18:23
Then if you divide 282.75 by 12 it will give you miles per gallon. That way you can compare it to what the old Kingswood was getting back in 1976.
Duncs
FollowupID: 514936
Reply By: JimDi - Sunday, Jul 22, 2007 at 12:44
I have the simplest system of all. I dont look, therefore I dont see, therefore I dont know.
That way I can still travel with my petrol 80 series happily towing my trailer.
When asked what the trip cost I say,I enjoyed it.
JimDi
AnswerID: 253831
Follow Up By: Col_and_Jan - Sunday, Jul 22, 2007 at 19:53
Like many others, I tended to get hung up on fuel usage. I once asked the father in law what his economy was like on his camper van when he traveled from Maryborough to Ipswich via the country roads. His comment was "great, spent only about 30 bucks on fuel (topping it up, but no actual figures), and that included lunch at Somerset Dam.
That was his approach. Its not the destination that is important, it's the journey.
Col
FollowupID: 514975
Follow Up By: ross - Monday, Jul 23, 2007 at 09:49
Knowing your average fuel consumption is vital if our planning a round oz trip,otherwise you may find yourself washing dishes for petrol money;)
FollowupID: 515058
Reply By: obee - Sunday, Jul 22, 2007 at 19:10
Quote...
To change into
miles per gallon (UK) miles per gallon (US) multiply by 0.833
miles per gallon (UK) miles per litre multiply by 0.22
miles per litremiles per gallon (UK) multiply by 4.546
miles per gallon (UK) kilometres per litre multiply by 0.354
miles per gallon (US) miles per gallon (UK) multiply by 1.2
miles per gallon (US) miles per litre multiply by 0.2642
miles per litremiles per gallon (US) multiply by 3.785
miles per gallon (US) kilometres per litre multiply by 0.4251
X miles per gallon gallons per 100 miles: divide 100 by X
(both gallons must of the same type)
X miles per gallon (UK) litres per 100 km: divide 282.5 by X
X miles per gallon (US) litres per 100 km: divide 235.2 by X
X km per litre litres per 100 km: divide 100 by X
X miles per litre litres per 100 km: divide 62.14 by X
Unquote
Some people like to work in litres per100 kilometer and others kilometers per litre. To switch between the two divide either into 100. eg 12 litres per 100k, divide 12 into 100. Answer = 8.33 (recurring ) kilometers per litre. 8.3333 etc into 100 = 12 litres per 100 kilometers.
I hope this covers all scenarios that you need.
Owen
AnswerID: 253895
Follow Up By: Batt's - Monday, Jul 23, 2007 at 00:19
Owen I'm sure Jon appreciates the trouble you went to. But seriously dude you need to get out more and go 4wheel driving. No harm intended ok.
FollowupID: 515035
Follow Up By: obee - Monday, Jul 23, 2007 at 22:54
Hi Batts
I wish I coulda worked out all by myself but I cheated and copied it and the copyright gestapo is hot on my heels.
He He
Owen
FollowupID: 515217
