Water supplies while.......
Submitted: Sunday, Jul 22, 2007 at 23:30
mightyQ
G'day, Today while on our way back home and discussing our next trip, my wife and I were wondering where all fellow travelers get their
water supplies?
This afternoon we filled our
tank (55litres) from the church grounds in a town we went through, this after going to parks in other towns only to find the taps missing!
Just wondering where others get theirs? we usually carry 140L and up until now have not had any trouble. We would be interested to hear how everybody else goes, especially as our next trip is going to be for at least 6 months
andy
Reply By: Scrubcat - Sunday, Jul 22, 2007 at 23:44
G`day Andy,
At the servo, before filling with fuel ask if you can top up with
water, If the answer is no, drive off to the next servo. ( only possible if there is another one before you run out of fuel though )
S.
253948
Follow Up By: Lochmonster - Monday, Jul 23, 2007 at 10:32
Watch out! I once did that and later when putting a brew on, the discovered the
water was tainted with fuel! Not good if you're remote! Tally Ho.
515068
Reply By: Russ n Sue - Sunday, Jul 22, 2007 at 23:51
We spent $300'ish and purchased a 4 stage reverse osmosis kit. The membrane is so fine that it removes all impurities from
water. I take advantage of any source of
water we find ourselves near, be it from a
windmill, stream, pond - anything except seawater.
I use a 12V pump to push the
water through the RO plant. It takes several hours to generate the 210 litres we can carry, so we usually try to incorporate a few activities like walking of photography to kill the time while it happens. Ideally we try to do it at an overnight stopover.
We even use it when at caravan parks as some of the
water we've come across has been a bit suspect.
According to the literature, the RO membrane removes bacteria and virii and the two test modules I purchased with it do confirm that the
water has no impurities once treated.
It beats having to carry a lot of
water for extended bush stays and with all of the other stuff we carry we would have room for more anyway.
Russ.
253950
Follow Up By: Russ n Sue - Sunday, Jul 22, 2007 at 23:55
Bugger!
"and with all of the other stuff we carry we would have room for more anyway."
make that "and with all of the other stuff we carry we wouldn't have room for more anyway."
I wish we could edit these posts.
Russ.
515033
Follow Up By: Gramps (NSW) - Monday, Jul 23, 2007 at 07:48
"I wish we could edit these posts"
but then we'd lose the spontaneity LOL
515043
Follow Up By: Nick R (VIC) - Monday, Jul 23, 2007 at 09:20
How big is the RO kit?
Nick
515050
Follow Up By: Russ n Sue - Monday, Jul 23, 2007 at 09:44
G'day Nick,
It fits into a fishing tackle box about 225mm x 225mm x 450mm
Russ
515057
Follow Up By: Member - eerfree(QLD) - Monday, Jul 23, 2007 at 20:31
R & S
Does the RO unit take as long to filter Good
water as it does to filter Bad
water? ---I think I need to Google this, can I ask what brand you have?
eerfree
515184
Follow Up By: Ianw - Monday, Jul 23, 2007 at 23:03
If the RO units dont work with seawater, why are they sold as emergeny units for liferafts?
Ian
515219
Follow Up By: Russ n Sue - Tuesday, Jul 24, 2007 at 00:33
ianw, it's not that it won't process seawater, it's just that seawater dramatically reduces the lifespan of the filters and membrane. If you were drifting in a life raft that would be the least of your concerns. So long as we plan
well, we should never have to use seawater.
eerfree,
we got ours from here here
cheers,
russ
515229
Reply By: Member - Oldplodder (QLD) - Monday, Jul 23, 2007 at 07:49
We have our
water in a number of containers, 2 x 20l containers (potable) , 1 x 20l (washing) and 60 litres in the CT
tank (washing, boiled for cooking).
This minimises the amount of good/potable
water we need to about 5 to 8 litres a day for the two of us.
We usually get potable
water by buying spring
water containers at supermarkets (10l containers and handy for carrying) or by topping up our 2 x 20l containers.
When we find good potable
water, we top up. Washing
water we pick up at most towns or caravan parks while we are there. Usually use a caravan
park every few days or so.
253959
Reply By: traveller2 - Monday, Jul 23, 2007 at 08:22
Usually at servo's and roadhouses or van parks if staying overnight.
Most local councils have removed the taps from parks and gardens and if fact most public amenities in the interest of saving
water. Sometimes they leave the taps but fit the funny tops which require a handle to be fitted when required, nothing to stop you getting a handle from a plumbers supplies ;-))
253963
Reply By: DIO - Monday, Jul 23, 2007 at 08:44
Taps removed obviously to conserve community
water supplies. Be prepared for any eventuation when travelling as servos or communities are (obviously) not obliged to supply travellers with
water (although in an emergency I'm confident that NO ONE would refuse
water to anyone in need). For drinking - try carton/bottled
water from the
Supermarket. Yeah sure it costs, but what doesn't these days. For washing/showering, looks like an occasional trip to a Caravan
Park or
Truck Stop.
Russ n Sue have the right idea, a 'reverse osmosis kit'. They are now really self sufficient - a liability to no-one. Way to go.
253965
Reply By: Member - Norm C (QLD) - Monday, Jul 23, 2007 at 09:36
Like others, service stations, caravan parks (on occasional stops there),
camp grounds are most typical. Have also filled at parks (less common these days as stated), a church and private homes (after permission of course). If there is a
Tourist Info centre, we sometimes ask there.
We carry 220 litres in 3 tanks (140,60,20). When necessary, we fill one of the larger tanks with
bore water and preserve others for drinking. We have never been short of
water, but on one occasion got to the point of boiling
bore water for drinking (just to be sure).
For remote travel, I think the key points are:
1. Carry plenty of
water
2. Fill up at each opportunity
3. Have more than one container in case of breakage and so you can fill with 'lower quality'
water while preserving
drinking water.
For emergency, I carry a packet of
water sterization tablets (the kind we used to carry in the Army). This is more for if we find ourselves stranded. Never had to use them and hope that stays the case.
We have never been refused
water and never had to pay for it. Though I would be prepared to pay for it if necessary.
253975
Reply By: Member - Doug T (W.A) - Monday, Jul 23, 2007 at 10:52
Like Scrubcat said at the servo , I have an 80lt in my Troopy with a tap out the back, I carry a short piece of hose and the tap fittings and hook it up , turn the taps on and fill.
253993
Reply By: Member - 'Lucy' - Monday, Jul 23, 2007 at 13:37
Troopy has a 220ltr stainless steel
water tank
CT has a 88lt ss
water tank.
Lasts us for 2-3 weeks including showers. Can stretch that out 56 weeks with out showers.
Longer if on minimal rations
Fill up from home before we leave.
254018
Reply By: Member - Royce- Monday, Jul 23, 2007 at 14:29
Essential part of travelling: a length of pipe with tap fittings AND the special tap keys needed for
park taps....
I used to also carry my favorite shower rose and a shifter. At dodgy van parks with showers that didn't work... swapped
mine. When finished, cleaned the thread and head of theirs, a bit of teflon tape and all's good. :-]]
254026
Reply By: mightyQ - Monday, Jul 23, 2007 at 22:03
G'day, thanks for all the positive answers, my wife is
well pleased and now more confident. Some great suggestions there and some we already use.
Thanks one and all again
andy
254143
