Smokey GU
Submitted: Monday, Jul 23, 2007 at 09:16
ThreadID: 47999 Views:1984 Replies:1 FollowUps:4
Hi all,
I have an 03 GU 4.2l ute, which has a 3 inch mandrell exhaust and has had the boost increased to about 12 psi. I notice it now blows alot of black smoke- mainly under load/acceleration. I was going to have it looked at until a mate recently had the same work done to his GU (4.2l, 3 inch exhaust and higher boost) and his is doing exactly the same. Is this a problem or is it normal for the patrol's?
regards
Brett
Reply By: Wayne-o (Pilbara WA) - Monday, Jul 23, 2007 at 09:48
Brett,
No this is not common. I have 4.2 iTD wagon, GU3, with 3" dump & exhaust, with stage 2 tubo upgrade, and boost running 14psi, and fuel wound right in, and not an ounce of smoke my man.
I would check your injectors perhaps.
What egt's are you getting, maybe the pump is too high?
Wayne-o
AnswerID: 253978
Follow Up By: brett patrol - Monday, Jul 23, 2007 at 09:55
yeah ok. exhaust temp will reach 450. I have seen some smokey Gu's and was told it is normal??
Maybe a good idea to have it checked out.
Brett
FollowupID: 515060
Follow Up By: Dave(NSW) - Monday, Jul 23, 2007 at 12:24
Wayne-o,
What did stage 2 turbo upgrade involve?
Cheers Dave....
GU RULES!!
FollowupID: 515080
Follow Up By: Wayne-o (Pilbara WA) - Monday, Jul 23, 2007 at 13:36
dave,
oversizing of both compressor and turbine, as well as larger and more efficient wheels. As well adjustable wastegate actuator, with boost set to 14psi.
stage one is only the compressor wheel oversized.
I compared the new tubo to the old one, and there is a definate difference in size, Inner diameter, and the turbine wheels have more blades.
Oh, and with the 3" exhaust upgrade, goes like a shower of the preverbial!!!
Wayne-o
FollowupID: 515092
Follow Up By: Dave(NSW) - Monday, Jul 23, 2007 at 13:54
Thanks Wayne-o,
I'll have to investigate a bit more about it over here on the Eastern side,
Cheers Dave....
GU RULES!!
FollowupID: 515093
