Calcium batteries
Submitted: Monday, Jul 23, 2007 at 19:29
Member - John
I have looked, honest..... I am looking to replace my two Delkor 27H-710 Calcium batteries, wondering if any one has bought any cheap ones in Melbourne/Dandenong way, recently? Thanks in advance, John
Reply By: Member - Duncs - Tuesday, Jul 24, 2007 at 08:57
John,
I had the same problem in
Sydney. No body had the Delkor. I eventually bought one from Coda Batteries at Sylvania Heights. IT is an 850CCA and is the same size physically as the M27. Just over $200.00
It is probably not a cheap option but if you need the help I could pick one up for you. Freight could be expensive though. Perhaps if you call them they may know a supplier in
Melbourne Their phone number is (02) 9544 6021 or www.codabatteries.com.au
Good Luck
Duncs
254187
Follow Up By: Member - John - Tuesday, Jul 24, 2007 at 17:07
Duncs, thanks for the info, I am sure I will be able to find them loccally, if not, I will ring them, Thanks, John
515305
Reply By: Graeme - Tuesday, Jul 24, 2007 at 09:43
Suggest you also have a look at the Supercharge Gold, same physical size, 760CCA and 160 min RC so a little more power and endurance than the Delkor, with 24 months warranty.
They are made in the Phillipines, to USA spec. The battery is a Calcium/Calcium terminal configuration as with Delkor.
Have had these in my 100 series for some while now after getting 6 years out of the OE batteries.
Run winch and two 170Watt
driving lights, so they do get some load and have been quite good.
254197
Follow Up By: Member - John - Tuesday, Jul 24, 2007 at 17:09
Graeme, thanks for that. John
515306
