HF noise from Turbo Diesel - FIXED ??
Submitted: Monday, Jul 23, 2007 at 21:49
ThreadID: 48034 Views:4380 Replies:6 FollowUps:8
Hi All, there has been a lot of info around concerning how to eliminate the engine noise in HF radio from new electronic engines. I was advised by Austek communications in Cairns to fit 3 Ferrite suppression sleeves side by side to the spill valve control unit cable.
It appears I havn't got the engine noise any more. Only tested out front at home I will do more testing and post again with results. Fingers crossed.
I own a 79 series L/C 2006 TD. Today I fitted the Ferrite suppressors from Jaycar Electronics (model u25, page 134 of Catalog) as I said 3 side by side along the cable close to the unit. Stay tuned for further updates !!!
Just my experiance
Barry
Reply By: time waster - Monday, Jul 23, 2007 at 22:16
hi barry i have the ngt in the new hilux and find engine noise too what is and where is the spill valve control unit?
AnswerID: 254144
Follow Up By: time waster - Monday, Jul 23, 2007 at 22:24
Is it the poss and neg battery input to the main unit?
FollowupID: 515207
Follow Up By: Barry 2 - Tuesday, Jul 24, 2007 at 23:01
Hi time waster, I'm no expert, don't know where the unit is located in a hilux,in my LC tray it is a black box approx 120mm x 120mm attached to the L/H guard in the engine bay has a loom coming out of it that goes across to the side of the engine and into the fire wall.I think it has something to do with the fuel management ???
not sure. As i said in my post when I was in Cairns I spoke to a tech at Austek who was very helpfull and showed me where to put the supressors didn't actually go into details about what the black box did,only said that it would make an improvement, so far test at home it appears that the noise has gone ????
When I get a chance I will test further out of town. My mate has a NGT in his Stnd 100 series LC and when I park next to him his radio picks up my engine noise it will be interesting to see what happens now. Here is the Ph No for Austek 07 40355544 ask for Warren (Tech) he is very helpfull. Hope this helps ?? ( clear as mud I supose !!)
Good luck
Barry
FollowupID: 515374
Reply By: Footloose - Tuesday, Jul 24, 2007 at 14:48
I've posted solutions on this problem before. I sincerely hope that your solution ends your problems.
Be sure to check on ALL the important frequencies that you use, as sometimes solutions can be frequency selective.
AnswerID: 254232
Follow Up By: Barry 2 - Tuesday, Jul 24, 2007 at 23:06
Hi footloose, I hope so tooooo ???
Thanks for the tip, when I do a better test out of town on all frequencies I'll post further
Barry
FollowupID: 515376
Reply By: Member - George (WA) - Tuesday, Jul 24, 2007 at 18:11
You mean a 100series 2006 T/D LC ?
AnswerID: 254251
Follow Up By: Barry 2 - Tuesday, Jul 24, 2007 at 22:45
Hi George, I own a 79 series LC Tray TD
FollowupID: 515371
Reply By: time waster - Wednesday, Jul 25, 2007 at 16:13
Thanks Barry for the contact would you be able to send me a picture when you have a chance of the box with the cable suppressors on it.
streets@sa.chariot.net.au
AnswerID: 254410
Follow Up By: Barry 2 - Thursday, Jul 26, 2007 at 01:20
No worries I'll try and send some photos give us a day or two, "Be warned I'm technically challenged" !! Not sure how photos will turn out, I had to move unit as I have fitted a duel Battery system and unit is mounted on side of battery tray.
Not a lot of room under the bonnet for mods in a 79 series,for photos I'll give it my best shot the suppressors are actually under the battery tray.
Barry
FollowupID: 515556
Reply By: time waster - Thursday, Jul 26, 2007 at 19:11
Thanks Barry look forward to your pictures we have the new hilux td which may have a similar to your box.
AnswerID: 254587
Follow Up By: Barry 2 - Thursday, Jul 26, 2007 at 21:13
Have e-mailed photos tonight, if you don't receive let us know
Barry
FollowupID: 515703
Follow Up By: yowie - Sunday, Sep 02, 2007 at 10:51
Hi Barry
I have the same Landcruiser as yours with the same problem with my HF radio, i was wondering if you could send me the pic's of were you installed the ferrite filters.
FollowupID: 521384
Follow Up By: Member - Mottleman (NSW) - Tuesday, Sep 04, 2007 at 10:01
Hi Barry
Photos for me too please if possible.
FollowupID: 521657
Reply By: time waster - Monday, Jul 30, 2007 at 11:12
Yes got them thank you very much will get some and try them.
AnswerID: 255040
