Thermoguard EGT unit.
Submitted: Tuesday, Jul 24, 2007 at 08:52
Member - Vince B (NSW)
I have received some helpful info from Ian regarding the abovementioned unit.
Has anyone fitted this unit to a Pajero DID motor & if so where was it placed. Before or after turbo?
Thanks for any assistance in this matter.
Vince
Reply By: ExplorOz Team - David - Tuesday, Jul 24, 2007 at 11:03
Vince,
I fitted
mine after the turbo mind you this is an 80 series. Do you have a port already available either before (in the manifold) or after the turbo (in the dump pipe)? When I installed the Denco it had a pre-drilled port in the dump pipe so install was simple.
254213
Follow Up By: Member - Vince B (NSW) - Tuesday, Jul 24, 2007 at 12:29
Thanks David.
I will take off all the plastic covers on top of the engine & have a look at the manifold & dump pipe.
515281
Reply By: Member - Oldplodder (QLD) - Tuesday, Jul 24, 2007 at 17:21
Have had one on my 2.8 for about a year.
Drilled and tapped the manifold just above the turbo.
Wasn't a place already available.
Before the turbo gives a better reading, but more hassle to install. :o)
254244
Follow Up By: Member - Vince B (NSW) - Tuesday, Jul 24, 2007 at 17:41
Thanks John.
Will have a look on the weekend. It appears before the turbo is the way to go.
Vince
515311
Reply By: zad - Thursday, Jul 26, 2007 at 11:39
The problem with fitting it before the turbo is that you're going to have to pull the turbo out to do it so you can clean the swarf out from tapping the hole - a hassle i could do without.
254525
