Snatch Straps & Towballs
Submitted: Saturday, Jul 28, 2007 at 15:25
ThreadID: 48179 Views:3863 Replies:9 FollowUps:20
Who has personal experience of breaking a towball during a snatch recovery?
This topic seems to enrage many whenever raised & I would be most interested to
hear of the strength of argument & stats that must exist to support the contention
that this is a very dangerous practice. I must confess to being guilty of this, a
serial offender in fact, but before a full confession I would like an indication of
my chances of surviving a mauling on this forum due to there being overwhelming evidence of the dangers ...oldbaz.
Reply By: Batman69 - Saturday, Jul 28, 2007 at 15:36
Oldbaz,
I personally have no experience with tow ball breakage but for evidence of the damage they can do check out the inside back page of the August 07 edition of Overlander magazine for photos of a rampant broken tow ball.....
I do have experience of a 5/8" diameter rams horn on my tow bar straightening and catapulting the snatch strap at an extreme rate of knots to the drowned vehicle I was extracating at the time. Since then I have only used rated recovery hooks !
Steve
AnswerID: 254834
Follow Up By: Member - Barry M (NSW) - Saturday, Jul 28, 2007 at 15:47
Thanks Steve, I will check the mag out. By rams horn do you mean the device
for attaching safety chains ? I have broken several straps & they invariably go
straight under the vehicle at a rate of knots, either forward or back depending on the site of break....oldbaz
FollowupID: 515940
Follow Up By: Batman69 - Sunday, Jul 29, 2007 at 14:12
Yeah Oldbaz,
It had two pieces of 5/8 rod coiled up like a rams horn and welded to the tow bar. I foolishly thought it would be strong enough to withstand the snatch... oh boy was I wrong on that one.
Steve.
FollowupID: 516093
Reply By: Member - Howard P (WA) - Saturday, Jul 28, 2007 at 15:55
Barry,
A good friend of ours, lost her brother when a tow ball broke during the recovery of a bogged vehicle. Would I use a tow ball as a recovery point - definitely Not !!
AnswerID: 254836
Follow Up By: Member - Barry M (NSW) - Sunday, Jul 29, 2007 at 07:58
Howard, sorry to hear of your sad experience. I was not condoning or recomending the practice, just seeking information...oldbaz.
FollowupID: 516031
Reply By: Outnabout David (SA) - Saturday, Jul 28, 2007 at 17:09
Why even bother to find out.
Do it properly in the first place.
AnswerID: 254850
Follow Up By: Member - Barry M (NSW) - Sunday, Jul 29, 2007 at 08:02
I bother to find out so that I may be a better informed person. Isnt that why people
ask questions on this forum ?.....oldbaz.
FollowupID: 516033
Reply By: Chriscd - Saturday, Jul 28, 2007 at 20:27
Only experiece regarding same was to see the result of a snatch strap dropped over the towball of a bogged OKA - out from Kununurra a few years back, took out the back window of the OKA trying to de-bog the one up to the axles, and also the front passenger seat headrest, the driver responsible is no longer returning every season to WA to drive OKA's.
Seeya
C
AnswerID: 254879
Follow Up By: Member - Barry M (NSW) - Sunday, Jul 29, 2007 at 08:07
Thanks for the info, While being aware that this was generally considered a
no no, I had not seen any direct evidence, but obviously this does cause
problems. cheers...oldbaz.
FollowupID: 516034
Reply By: Member - Brian (Gold Coast) - Sunday, Jul 29, 2007 at 07:35
"Who has personal experience of breaking a towball during a snatch recovery?"
Not me..... but I have heard enough anecdotal evidence to convince me that the extra couple of minutes to do it the accepted way is prefferable to risking hurting/maiming/killing someone. Towballs just aren't meant for snatch strap force.
Here's a thought though, I have a rated recovery hook permanently attached to a spare tow tongue so when it's necessary for me to recover someone or be recovered backwards, I simply slide it in the hitch and the strap sits over it, (no shackle then either...... they can now be purchased from ARB (I think) ready to go... )
Brian
AnswerID: 254906
Follow Up By: Member - Barry M (NSW) - Sunday, Jul 29, 2007 at 08:12
Brian, like you I had only anecdotal evidence of the dangers involved, but as you can see, people have experience of the results of this action & I am now convinced.
Your option with the recovery hook & not needing shackles would seem a most
effective alternative. Thanks for your input...oldbaz.
FollowupID: 516037
Follow Up By: Outnabout David (SA) - Sunday, Jul 29, 2007 at 09:00
I am interested in knowing you attach a tow hook permanantly to an old hitch?
I have seen the commercially avail receiver hitches but can't work out how you would attached the hook to the tongue
FollowupID: 516041
Follow Up By: Member - Roachie (SA) - Sunday, Jul 29, 2007 at 13:51
David,
I think they bolt the hook to the square section....NOT the flat tongue that the towball would normally bolt onto. You'd need to obtain a suitable length of the 50mm (?) box section, or butcher a proper goose-neck by cutting off the flat bar.
I wouldn't trust the flat bar section.....some blokes use a shackle through the tow-ball's hole........to me, this just adds another potential breaking point (ie: the weld between the flat bit and the box section).
The hook bolted to the box section is probably as safe as simply attaching the snatch strap to the square housing of the towbar, using the retaining pin, although that pin is less-likely to be bent if the square-section plus hook is used as the main area for stress is in the "sheer" of the pin, whereas with the strap in the square hole, the stress is on the centre of the pin and I've heard of them bending (but never witnessed this).
Roachie
FollowupID: 516085
Follow Up By: Outnabout David (SA) - Sunday, Jul 29, 2007 at 19:05
yeh roachie I know how the bought ones are made. I was a bit concerned that as he said he used an old towbar tongue that he may have welded a hook to it which would be a disaster waiting to happen.
FollowupID: 516130
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Jul 29, 2007 at 20:34
Think Barry's question is a bit macabre actually.
I have been given a butt plug actually. No, not one of those, but a solid square steel piece with a heavy duty shackle through it ready to yank a Yota. I usually just have a pin through the square section.
David, that does sound a worrying tone.
FollowupID: 516140
Follow Up By: Member - Brian (Gold Coast) - Sunday, Jul 29, 2007 at 20:49
Outnabout David,
We are taught to use a rated shackle to attach the strap to the tongue of a tow bar. I know that in other states, this isn't taught, and as I understand it, other states (not sure where) are taught to attach the strap via the pin in the hitch receiver. Comes down to who is shown what according to who's standards I guess. But anyway, here on the Gold Coast, and as far as I know, in Queensland, that's the way it is. So I had a spare tongue, not a rusty old one that was ready for the bin or anything but a spare one in good order. I went to ARB and bought a rated recovery hook, replaced the high tensile nuts and bolts that come in the pack with higher grade high tensile nuts/bolts, drilled holes in the tongue, the flat bit that would normally hold the tow ball, and attached the recovery hook to it that way. Works a treat! And doesn't utilise a shackle! Although I guess the chances of a rated shackle coming off are about the same as the hook coming off. I didn't come up with this idea, I copied from some others that I had seen but sure do wish that I had applied for a patent on it as there are a few variations on this idea nowadays.
The other thing is that, in my experience, snatch recovery's don't need to be performed at break neck speed. In fact the easiest recovery's I have participated in have been the tow vehicle slowly driving forward, stretching the strap which then transfers the stored energy to the "recovered" vehicle and voila! Un-stuck fourby!
Roachie,
I have seen a pin that was bent by a strap, probably the result of a recovery performed with far too much throttle. I agree that with the tongue in, the pin is being used in the way it was designed, not with the entire load exerted on the centre of the pin.
Our club's Driver Awareness Program is (again, to the best of my knowledge) based on the National Code. But this debate comes up a fair bit as far as whether to use the pin or a shackle (or in my case a recovery hook) to hold the strap. If I didn't have my hook/tongue, or a shackle I wouldn't hesitate to try the strap-down-the-hitch-centre-and-use-the-pin-to-hold-it trick, but I would NEVER, EVER drape o strap over a tow ball.
Brian
FollowupID: 516142
Reply By: Ozboc - Sunday, Jul 29, 2007 at 09:40
I'm guessing if someone had a personal experience with a ball breaking whilst snatching , they would be unable to post a reply :)
But on the serious side , Ball breakage is something that may be a freak occurance , but it can happen. Its the same as you would not stand next to a winch cable when its being used , or stand under a load from a fork lift or a crane.
You may get away with it for years , but the one time it does fail , you may not know about it , but your friends and family will certainly know.
Gambling is best left to the casino or the newsagency on a saturday morning before your 4x4 trip.
AnswerID: 254922
Follow Up By: Member - Barry M (NSW) - Monday, Jul 30, 2007 at 17:16
Fair comment, following the info received I shall certainly mend my errant ways..
cheers...oldbaz.
FollowupID: 516254
Reply By: Member - Hughesy (NSW) - Sunday, Jul 29, 2007 at 10:13
Hi Barry. As Ozboc has said I think its more of a freak/unfortunate thing when it happens. Remember these things are designed to withstand the strain of slamming on your brakes and having a 3.5t trailer pushing against it or vise versa for accelerating...day in day out. The diamter of the weakest/thinest part would have to be 20mm plus. Compare that to 2 10 or 12mm bolts that hold most peoples recovery hooks on or the ~16mm pin that actually holds your towbar reciever in place???
Yes the forces in a difficult snatch can get higher than that as with the case mentioned above with the OKA's. No, you never know what abuse someone's towball has had. Would I use one for light to medium bogs - yes. I reckon there are more cases of inadequate vehicle recovery hooks breaking loose than towballs that break. And in each case it would be operator abuse.
Yes I'll cop all the do-gooders saying this is wrong. I reckon you have more chance of sliding down a wet, muddy hill and hitting a tree than breaking a towball in most snatch situations - and we all attempt those sorts of things without much thought.
AnswerID: 254925
Follow Up By: Member - Barry M (NSW) - Monday, Jul 30, 2007 at 17:19
Your thoughts are similar to mine, but in light of all info received I shall desist in
future & I thank you for your input....oldbaz.
FollowupID: 516255
Reply By: Jacked Off - Sunday, Jul 29, 2007 at 13:39
I have seen a complete tow bar ripped off the back of a cruiser doing a recover. fortunately for the driver of the other vehicle the towbar just missed the windscreen of the vehicle but it did peel back part of his roof right above him.
VERY scary!
AnswerID: 254947
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jul 30, 2007 at 15:52
Cark, that'd soil your Jocks.
Geoff
Geoff,
FollowupID: 516235
Reply By: RobAck - Sunday, Jul 29, 2007 at 19:22
Let me put it this way. Over the last four years two people have been killed by tow balls as a result of snatch straps being connected to them. As a result and apart from the fact that tow balls are only rated for a vertical load NOT a horizontal and shock load, the use of snatch straps on tow balls has been well and truly banned by Workcover in all States and Territories and warnings issued.
Apart from that the national 4WD training standard specifically advises against the use of tow balls for recovery for the quite specific safety reasons stated above.
There is also a littany of near misses as a result of ignorance or arrogance I am never sure which.
As an OHS&W consultant the recommendation is never. I don't really care how many times it has never happened I can assure you the risk is extremely high and the result can be terminal.
I guess these comments will stir things up but they are factual
RobA
AnswerID: 254977
Follow Up By: Member - Hughesy (NSW) - Sunday, Jul 29, 2007 at 20:20
Rob, Not having a go at you but the statement about towballs not being rated for horizontal forces is rubbish. The vertical force on a towball is max 350-400kg for a 3.5tonne trailer.....a 2" piece of 4mm rod will hold that up.
Towballs are purely rated on the horizontal force applied such as in accellerating and braking when all the force is being applied horizontally thru the towball. How much shock load do you reckon goes thru a towball when you are on and off the throttle???
Look I'm far from promoting the use of towballs as a recovery hook but there is alot of BS floating around about them.
Would people use a pintle hook as a recovery point??? Whats the difference??
FollowupID: 516138
Follow Up By: Member - Brian (Gold Coast) - Sunday, Jul 29, 2007 at 20:52
"Towballs are purely rated on the horizontal force applied such as in accellerating and braking when all the force is being applied horizontally thru the towball. How much shock load do you reckon goes thru a towball when you are on and off the throttle??? "
Nowhere near as much as when performing a snatch recovery I would think. Snatch straps are rated at 8500kgs, (some more)..... the shock load on a tow ball would be way past it's rating in my opinion. I am happy to stand corrected on that though.
Brian
FollowupID: 516143
Follow Up By: Member - Hughesy (NSW) - Sunday, Jul 29, 2007 at 23:37
Hi Brian,
Not doubting you there mate. If you were doing a snatch that was going to excert up to the max breaking strain of the snatch strap it wouldn't matter what you had it attached to ...I'd be very worried.
The other thing in "defence" of the towball is that the loads applied to it are shock loads when towing (ie hard braking) whereas a snatch strap applies a "progressive" (although still relatively quick) force.
It would be interesting to see how much horizontal force is applied to a towball if you were towing a 700kg (unbraked) trailer at 110km/h and slammed on the brakes????? Someone may be able to do the calcs on it, but I reckon we'd all be shocked at what that force is......and they obviously have to be able to withstand that force with a good factor of safety aswell.
I'm not doubting that towballs have broken in recovery excercises but I bet the towball was a cheap one......a bit like how much strain you can but on a $2 spanner and a $25 spanner
FollowupID: 516158
Follow Up By: Ingtar - Monday, Jul 30, 2007 at 15:11
"The other thing in "defence" of the towball is that the loads applied to it are shock loads when towing (ie hard braking) whereas a snatch strap applies a "progressive" (although still relatively quick) force. "
The fact that the trailer is constantly connected to the towball doesn't allow 'shock' loads. While they may be sudden, they are applied at the same rate they are applied to the vehicle. Further, the trailer is (generally) a rolling load. Whilst you may be able to tow a 3.5 tonne trailer, it is a very different thing to pulling out a bogged vehicle.
"Snatch strap applies a progressive force...." only once it has taken up slack. A lot of the time when you are in boggy areas the recovering vehicle has difficulty taking off at a crawl, so there is in fact a shock load applied.
"I bet the towball was a cheap one......" And where do you actually buy expensive towballs? I bet the majority of towballs are constructed out of very similar grade steel, with the only thing I know of having changed being the diameter of the thread.
Whilst I have never seen a towball snap, I have seen some *unnamed government organisation* attempt some vehicle recovery using a combination of snatch straps, chains and ropes, and seen the rate at which they cover a couple of hundred metres from a standing start. Try doing a towball recovery near me and I won't be very pleasant to you at all.
FollowupID: 516229
Follow Up By: Member - Brian (Gold Coast) - Monday, Jul 30, 2007 at 16:23
Sorry Hughesy, I have to say I'm still against towballs as a recovery point. Trailers connected to the towball wouldn't exert a great deal more shock load to the towball than it is already experiencing I would think, simply because the trailer is connected via a solid draw bar. When a snatch stfrap is used, "most" people drive off a breakneck speed, the strap does it's stretchy thing and then at the end of the "stretch", the other vehicle should emerge from whatever has it bogged. BUT, if the stuck vehicle is really stuck, then everything comes to a sudden STOP! And all of that pent up energy has to be released somewhere. And my bet would be the tow ball, again simply because it is designed to "tow" and not "recover".
Brian
FollowupID: 516242
Follow Up By: Member - Barry M (NSW) - Monday, Jul 30, 2007 at 17:27
RobA, thanks for your input. I am not competent to enter into the load/force
arguments above, but suffice to say the info gleaned from you & others will see a
change in my recovery strategy & I appreciate everyones opinion....oldbaz.
FollowupID: 516256
