Cleaning engine bay
Submitted: Saturday, Jul 28, 2007 at 16:33
ThreadID: 48181 Views:2662 Replies:2 FollowUps:5
Hi all
I've managed to get the engine bay of my diesel rodeo all caked in mud (as you do). As a 4wd and diesel engine novice I am wondering if I can take a high pressure hose to it or is that a big no-no. Any advice on cleaning it would be much appreciated.
thanks!
Reply By: Kev. (Cairns) - Saturday, Jul 28, 2007 at 16:45
Why not just use the garden hose ?
My theory is go for it & if something goes wrong then fix it & make sure it doesn't happen again, id rather it happen at home than out bush.
AnswerID: 254845
Follow Up By: DIO - Saturday, Jul 28, 2007 at 17:30
Don't use the hose as you'll get pinged for breaching water restrictions.
FollowupID: 515962
Follow Up By: Kev M (NSW) - Saturday, Jul 28, 2007 at 17:33
Dio,
It depends on where you live, if you do have water restrictions then go to a car wash place but be discrete as most operators don't like it.
Kev
PS Mt Isa for example does not have water restrictions
Russell Coight:
FollowupID: 515964
Reply By: Outnabout David (SA) - Saturday, Jul 28, 2007 at 17:07
Just keep clear of giving electrical things a big soaking like your alternator or use box.
if it is muddy the sooner you gt it off the easier to remove but a high pressure blast ont do it alone. You will still need to get a brush rag or whatever and rub it off as well.
I try to avoid it as it is a pain to clean.
Also b carefull it has blocked your radiator or air cond fins. .....But don't put a high pressure hose through there.
AnswerID: 254848
Follow Up By: Member - Linda M (VIC) - Saturday, Jul 28, 2007 at 18:33
Thanks for the advice so far. I'm not worried about hoses etc- I'll be taking it to the car wash. Its the electrical issues that David referred to that worry me most. There is a bit of mud on the radiator so if I can't use the high pressure hose there, is a regular hose ok or should I just throw a bucket of water in there? Are the alternator and the fuse box the main things to avoid getting wet?
thanks again
Linda
FollowupID: 515977
Follow Up By: Patrol22 - Monday, Jul 30, 2007 at 12:53
Linda - the most expensive bit to fix if you flood it with water is the engine management computer.......you will need to take out a second mortgage if you damage this.
FollowupID: 516202
Follow Up By: Member - Linda M (VIC) - Monday, Jul 30, 2007 at 14:28
Thanks Patrol22, sounds like I'm better off keeping mud and not washing the engine bay at all. Damn...it was so new and shiny before it went through those big puddles!! Lol.
FollowupID: 516217
