body twist
Submitted: Saturday, Jul 28, 2007 at 17:01
ThreadID: 48182 Views:1779 Replies:4 FollowUps:4
hi guys
i have a 94 hzj 75 landcruiser ute just wandering if anybody can help me out,i have a problem with the body walking, when i hit the accelerator it seems to twist then when you back off it straightens up, this happens when you are driving from about 50kmh up it only does this a little bit.but it is enough to annoy me.i have replaced all shocky rubbers,but i think the drivers side rear shackle is faulty it has a fair amount of play in it when you jam a lever bar in there could this be the problem any help would be great.
Reply By: bob&loz - Saturday, Jul 28, 2007 at 17:57
brentos
It could be an axle alignment issue. check the distance from front wheel centre to back wheel centre on each side and see if they are the same
AnswerID: 254858
Follow Up By: brentos - Saturday, Jul 28, 2007 at 18:04
i forgot to mention that i have already done that and all is good ,it only started doing it about a week ago.i thought that maybe because of the forces on the diff under acceleration it is tmoving the worn shackle and causing the body twist
FollowupID: 515969
Reply By: Member - Lance S (VIC) - Saturday, Jul 28, 2007 at 18:18
We had the same problem with one of our trucks at work, and found that the centre bolt in the rear spring was broken. Good as new now.
cheers , Lance
Home Away from Home
AnswerID: 254861
Follow Up By: brentos - Saturday, Jul 28, 2007 at 18:32
thanks,ill look into it.is there much involved to change the centre bolt in the leaf spring.any other comments on the problem would be much appreciated
thanks,brentos
FollowupID: 515976
Reply By: Peter 2 - Saturday, Jul 28, 2007 at 18:39
You haven't got a cracked chassis have you?
A friend had a similar problem and the front tubular crossmember was cracked on both sides and the RH chassi rail was cracked behind where the transmission crossmember is bolted on.
Apparently it is not that uncommon in 75's, his literally fell apart when the body was unbolted from the mounts as the body, transmission and front springs/diff housing where holding it all together.
AnswerID: 254866
Follow Up By: brentos - Saturday, Jul 28, 2007 at 19:14
i have been under the truck several times and have had a pretty good look at the chassis i haven't noticed any cracks,its pretty tidy underneath if it was a cracked chassis i would think that i would be able to feel flex in the truck all the time or a bad ride at the least, but im really not sure. the truck drives perfectly the suspension is nice and firm except the dodgy rear shackle
FollowupID: 515983
Reply By: Fazz - Saturday, Jul 28, 2007 at 19:31
Brentos
I would replace all your shackle bushes (front & rear) They are just about a regular service item & will certainly cause your complaint.
Cheers Fazz.
AnswerID: 254876
Follow Up By: brentos - Saturday, Jul 28, 2007 at 19:49
that what i am steering towards(shackle bushes)i just cant see what else it would be.it definently feels like somthing in rear suspension and diff area
thanks for your help guys.
FollowupID: 515989
