LPG/4.5 Lt 100 series
Submitted: Monday, Jul 30, 2007 at 19:13
ThreadID: 48240 Views:4675 Replies:6 FollowUps:3
Hi all
thinking about putting LPG on 4.5Lt 100 series do I need flashlube valve saver kit and can you only use their valve saver fluid or are there other options
any replies welcome
Thanks oldpop
Reply By: Robin Miller - Monday, Jul 30, 2007 at 19:51
Wouldn't think of not using the Flashtube Oldpop.
There are other options - but I don't personnaly use gas or it. If your post fails to come with answers I'm sure I can come up with reccomendations in a few days.
Unfortunately a friend of mine had problems with his 4.5lt 80series gas installation and has had it removed.
It really is one of these things that can work but only if implemented well.
Robin Miller
AnswerID: 255105
Follow Up By: oldpop - Monday, Jul 30, 2007 at 20:09
Hi Robin
Thanks for your reply
see how it goes
Regards oldpop
FollowupID: 516300
Reply By: TD100 - Monday, Jul 30, 2007 at 20:11
i had my 80 series 4500 on gas and it was a nice installation,run well but the economy especially towing the caravan was very disapointing.cheers Paul
AnswerID: 255111
Follow Up By: zumzum - Tuesday, Jul 31, 2007 at 08:27
300 km on a full LPG tank? (90 lt ) ... ???
I'm very disappoined too!!
FollowupID: 516347
Reply By: Member - Rob S (NSW) - Monday, Jul 30, 2007 at 21:20
I have had a flash lube fitted to my 80 series for about 2 years and found it ok.
Morey's is another system available i have seen at super cheap.
Nulon make a valve saver lube as well a little cheaper that would work in a flash lube system.
I buy the 5 liter containers of flash lube and get about 25/30 thousand klm from it.
I found flash lube avaiable in most places even in the outback.
As for if the lube saves the valves or is it worth while you will get good and bad feed back.
I will always use it running on lpg.
And it makes me feel warm and fuzzy to do so.
Rob.
I only ever made one mistake
and that's when I thought I was wrong!
AnswerID: 255124
Reply By: CraigB - Monday, Jul 30, 2007 at 21:50
Hi bigpop,
I have an LC100 v8 on gas and have the Flash Lube installed.
When doing my research everyone bar none strongly suggested that one or similar be installed.
I buy mine in a 1 litre container.
This lasts me about 10 tank fulls or about 4500km.
I can't see the point in purchasing larger quantities just to sit around for up to a year or so.
I have never had any trouble in finding when it when required even in smaller country towns.
Craig
AnswerID: 255132
Reply By: Ray Bates - Tuesday, Jul 31, 2007 at 09:18
I have an 80 series on gas and it is fitted with a Flashlube BOTTLE but I use good quality two stroke oil. 250,000 Kls now no problems
AnswerID: 255171
Reply By: Robnicko - Thursday, Aug 02, 2007 at 11:31
Oldpop
I have had my 80 (4.5P) on LPG since 1998. I have had flashlube on it since the conversion and never had any issues. You can also pour the flashlube into the fuel tank as it cleans injectors very well. I go through about 1.5lt a year of flashlube and that works out to about $20.
I also use it in my trailbike and can only reccomend it. A mate who's a mechanic once said to me that alot of people reckon it's a gimmick but he beleives it is a good thing as do I. My cruiser now has 270k on it and has done 200 of that with LPG. Runs as smooth as new and has never had an issue with valves. However with the engine bay bottle feeder I will, on long trips, adjust the tap so it feeds more oil into the motor. Otherwise 1 drop every 5 seconds.
Rob
AnswerID: 255448
Follow Up By: oldpop - Thursday, Aug 02, 2007 at 18:43
Hello Robnicko
Thanks for the info
will give it a go
get the gas fitted in about 4 weeks time have to wait for a kit
Regards Oldpop
FollowupID: 516665
