Giving the cargo barrier the chop
Submitted: Monday, Jul 30, 2007 at 20:45
ThreadID: 48248 Views:2858 Replies:7 FollowUps:0
I am thinking of removing all the mesh on the lower part of my cargo barrier so i can utilize the dead space between the cargo system and the secons row of seats. Can anyone see any problems doing the above? Would be cheaper than selling the full cargo and replacing it with a half.
Reply By: fishaholic - Monday, Jul 30, 2007 at 20:57
I did that with mine, because of my home made drawer system. It made it alot safer being able to have a cargo barrier and was alot cheaper to cut it in half rather than have another built.
Crawf
AnswerID: 255120
Reply By: Member - Luke (SA) - Monday, Jul 30, 2007 at 21:29
I would do it.
Cheers Luke
AnswerID: 255127
Reply By: Crackles - Monday, Jul 30, 2007 at 22:13
Depending on the design of the barrier it may reduce its stregnth particually if you change the lower mounting points. When I built my storage draws I incorperated a top half barrier above it mounting to screws in the roof & the sides of the boxing system. If the draws & barrier are secure any new welding done professionally, I can't see a problem with giving it the chop particually as it can give as much as 15% more packing space in the rear of some cars.
Cheers Craig............
AnswerID: 255137
Reply By: Member - Ivan (ACT) - Monday, Jul 30, 2007 at 22:54
I've done it in two cars now - Prado had a horizontal support, so I just cut the mesh - see Site Link
100 series had a H shape frame in the middle, so I cut the two bottom legs of the H off and welded them on horizontally (to make a _I_I_ shape in the top half) - then cut the mesh off the bottom - same result.
Heaps of extra space - I used mine for water system - see above
AnswerID: 255144
Reply By: Michael ( Moss Vale NSW) - Tuesday, Jul 31, 2007 at 10:57
Do it carefully and dont make a mesh!!!!
AnswerID: 255182
Reply By: Wizard1 - Tuesday, Jul 31, 2007 at 12:57
Cargo barriers are built to meet certain Australian Design Rules. You shouldn't really be attempting to effect the build integrity of the barrier and its compliance with the ADR.
You may well effect its ability to do the job it was designed and tested to do.
Be aware of any fault that may fall on your part if there should be a injury as a result of an accident.
I would be getting one professionally made that complies with the ADR. At the end of the day it is ablout the safety of the passengers isn't it?
I think Balck Widow make a range of barriers, etc for various 4WD.
AnswerID: 255201
Reply By: Member - Barnesy (SA) - Tuesday, Jul 31, 2007 at 13:04
As long as you can sort out a way to secure it well at the bottom then i don't see a problem. mine is cut less than half and i just secure to the storage system with a couple of U bolts. Still very strong.
Barnesy
AnswerID: 255203
