REEFER REFRIGERATION
Submitted: Tuesday, Jul 31, 2007 at 16:10
ThreadID: 48271 Views:6718 Replies:11 FollowUps:2
REEFER REFRIGERATION - REFRIGERATION RESEARCH
DOES ANYONE KNOW WHAT HAPPENED TO THIS COMPANY
WE CANT GET IN CONTACT WITH THEM
Reply By: Scoof - Tuesday, Jul 31, 2007 at 16:21
not 100% positive but I think it has closed down.
Scoof
AnswerID: 255218
Reply By: Kev M (NSW) - Tuesday, Jul 31, 2007 at 16:21
Try this
Liemack Refrigeration Products. 12 Secker Rd Mount Barker SA 5251. p: (08) 83983537
Kev
Russell Coight:
AnswerID: 255220
Reply By: Matt(WA) - Tuesday, Jul 31, 2007 at 16:28
Try ruey shing. They now make these fridges and can supply parts for them. I am fixing one at the moment and contacted them and they can get bits
www.rueyshing.com.au/web/fsproduct.htm
Matt
AnswerID: 255221
Reply By: LEEANNE - Tuesday, Jul 31, 2007 at 16:29
thanks guys
AnswerID: 255222
Reply By: Patrolman Pat - Tuesday, Jul 31, 2007 at 18:59
They have closed down. A mate of mine bought a lot of their fridges as part of the closing down sale.
AnswerID: 255244
Reply By: Michael ( Moss Vale NSW) - Tuesday, Jul 31, 2007 at 20:51
Thats a shame if they have closed down.. I have a 90 litre Liemack and it has been great over the last 8 years. Its no doubt the best fridge on the market,,, isn't that right everyone??? :) Michael
World war 3 starting now!!!!
AnswerID: 255259
Follow Up By: Mainey (WA) - Wednesday, Aug 01, 2007 at 00:12
Michael, yes your correct :-)
FollowupID: 516444
Reply By: Hairy - Tuesday, Jul 31, 2007 at 22:41
Did you say "Reefer"!
When I went to school a reefer wasnt a fridge.
No wonder they have closed down or moved???
AnswerID: 255285
Reply By: Steve from Top End Explorer Tours - Tuesday, Jul 31, 2007 at 23:26
Please stop yelling.
Steve.
AnswerID: 255294
Reply By: Mainey (WA) - Wednesday, Aug 01, 2007 at 00:30
Leeanne
what is it you desire ?
AnswerID: 255299
Reply By: wheeleybin - Friday, Aug 03, 2007 at 07:57
Reefer was taken over by an Internatioanal syndicate that thought they knew everything lost the designer of the fridges and went down the gurgler.
The Reefer and Liemac (Earlier name) run a Mitsubishi Rotary compressor.
The reefer can basically be fixed by any fridge mechanic as the only pipeing joints are external and all internal piping is continuous so should not be leaking.
They are valved on both the high side and the low side and if gasing should be evacuated on both high and low or will not work efficiently.
The only thing a fridgy could not do is fix the inverter and controller and the firm that built these items them still exists in South Aus.
Rod Dun of Rods Country Camping used to distribute both Liemac and Reefer and he is a top bloke and he travels the show circuits and still uses a Liemac himself.
I believe he is currently at the Wauchope NSW 4x4 show and he might be able to guide you as to what you can do .
You can contact him on 0418423610 .
ian
AnswerID: 255606
Follow Up By: wheeleybin - Friday, Aug 03, 2007 at 08:04
OOPs should have read the lot.
The genuine Reefer is what I spoke of and the poster above is correct in stating that Ruei Shing can help with the plastic models that came in the 40L 60L and 100L and a later steel one.
The good fridge was expensive and designed and built in Mt Barker and was an excellent product.
The designer still has the first ever Liemac in his Cruiser and a fisherman near me has one of the originals also and it has never missed a beat and runs 24/7 in the back of his hilux twin cab.
ian
FollowupID: 516732
Reply By: ronvw - Monday, Aug 06, 2007 at 16:02
leeanne.Ihave 70 L liemack(the original company)then taken over by Refrigeration Research and called Reefer. I had problem with the inverter and found Trisan Aust Pty Ltd make and service the inverters for these fridges Trisan Aust Kent Town SA 0883631770 contact name Leanne .Ron.
AnswerID: 256090
