12v wiper motor
Submitted: Wednesday, Aug 01, 2007 at 18:49
Member - shane (SA)
can someone tell me if a windscreen wiper motor will reverse if the wires are changed around? may be off a HQ or similar.
Reply By: Mike Harding - Wednesday, Aug 01, 2007 at 18:52
Most likely. Try it and see.
Are you converting to left hand drive? :)
Mike Harding
PS. You may find it has more than two wires.
255381
Follow Up By: Member - shane (SA) - Wednesday, Aug 01, 2007 at 19:45
no not converting, i have been using my cordless drill to wind the jacks up and down on the van, so had this idea after seeing the motor on the new roller door. the motor on the door looks like a wiper motor. if a wiper motor is reversible i could use it on the jacks.
516528
Reply By: Ianw - Wednesday, Aug 01, 2007 at 18:56
If it is a permanent magnet motor it will. If it is like some older ones that have field windings then it won't.
Ian
255382
Follow Up By: Member - joc45 (WA) - Wednesday, Aug 01, 2007 at 20:08
Agreed. Try it, nothing to lose. If it doesn't reverse, then it's got field windings.
With a field winding motor, if you can get access to the guts, reverse the field windings without reversing the armature windings and you can then reverse the direction.
Most modern wiper motors have permanent magnets.
Gerry.
516529
Reply By: Robin Miller - Wednesday, Aug 01, 2007 at 20:06
It Will
Robin Miller
255396
Follow Up By: Member - shane (SA) - Wednesday, Aug 01, 2007 at 20:41
thanks all, ill keep you posted.
cheers, shane.
516540
Reply By: RoyHarv - Wednesday, Aug 01, 2007 at 20:55
Hi Shane
You might get some good ideas from www.autolegs.com.au
I have one of these systems and it's great!
Motors are about the same size as wiper motors!
Cheers Roy
255404
Reply By: Member No 1- Thursday, Aug 02, 2007 at 07:45
the ones for returning airpistol targets at the club do
255429
Reply By: Member - Mike DID - Thursday, Aug 02, 2007 at 10:24
Another cheap source of geared motors is 12 volt cordless drills.
255437
