1HZ Timing Belt
Submitted: Friday, Aug 03, 2007 at 18:15
Kev M (NSW)
When does the timing belt for a 1HZ motor need to be done is it 100 000km or 150 000km
Cheers Kev
| Russell Coight:
Reply By: Member - Doug T (W.A) - Friday, Aug 03, 2007 at 18:27
Every 100,000
255708
Reply By: thomasando - Friday, Aug 03, 2007 at 18:34
100,000
255710
Reply By: Kev M (NSW) - Friday, Aug 03, 2007 at 18:46
Thanks I was pretty sure it was 100 00km
Cheers Kev
| Russell Coight:
255712
Reply By: Member - Hughesy (NSW) - Friday, Aug 03, 2007 at 20:27
Kev, I don't know when or why it changed but the 75 series (atleast up to 97) are 100k but the 100 series (01) I have now is 150k. The belt would be exactly the same.
Probably an initial case of Toyota being over cautious and later revising it to 150k. I know when I changed
mine on the 75 it still looked pretty much like new with no cracking or signs of deterioration. They don't cost much or take too long to change so no harm in doing it at 100k.
255731
Follow Up By: Kev M (NSW) - Friday, Aug 03, 2007 at 20:31
Hughesy,
It's an 05 100 series Standard Dual Cab, I think it will be safer to replace it and keep it as a spare.
Cheers Kev
| Russell Coight:
516852
Follow Up By: Steve from Top End Explorer Tours - Saturday, Aug 04, 2007 at 23:05
Hey Kev
A 05 100 series is 150000 no problems, it is no use changing it at 100000 and keeping it as a spare, the reason being is if the new one lets go the whole engine will let go.
When I do
mine I do the cam shaft seal, belt, tensioner spring,
water pump.
A few dollars more but IMOA worth it.
Cheers Steve.
516986
Reply By: GerryP - Friday, Aug 03, 2007 at 21:35
Mine's a 1999 105 series and the manual states 150,000.
Gerry
255744
Reply By: Member - Reiner G (QLD) 4124 - Saturday, Aug 04, 2007 at 00:12
on my 95 model a light comes on in the dash..........every 100.000. When I replaced
mine the fuel consumption improved and it idled better.
I compared the belts and the new one was about 5 mm shorter.
Reiner
255769
Reply By: jon p qld - Saturday, Aug 04, 2007 at 07:50
As others have mentioned on 75 and 80 series cruisers its 100,000kms which changed to 150,000km's when the 100 series came out. It's a cheap belt around $50 for a genuine one and takes about half an hour to fit, so I'd do it at 100,000km's regardless.
Regards Jon
255779
Reply By: Member - 'Lucy' - Saturday, Aug 04, 2007 at 22:45
Yes.
255854
Follow Up By: Kev M (NSW) - Sunday, Aug 05, 2007 at 07:51
| Russell Coight:
517003
Reply By: Member - 'Lucy' - Monday, Aug 06, 2007 at 01:02
Glad to help anytime on anything. (LOL)
Its 100,000 as above
The T-Belt light on the dash should come to remind you.
I had
mine changed at 96,000kms when a few other things had to be done (fixing my 'smashing' good time).
They obviously tripped the light switch as it didn't come on at 100,000kms.
Then again if yours doesn't come on at 100,000kms it might be one of those set for 150,000kms
As someone else said they are a very cheap item to replace, but a very expensive one if they break.
256008
