Electric Brakes Camper Trailer
Submitted: Saturday, Aug 04, 2007 at 21:12
rylie
We have just bought a second hand camper trailer that is fitted with electric brakes and need advice on the following:
Will the brakes work without an electronic trailer brake control.
Which brand of electronic brake control is good we have looked at the Prodigy.
Reply By: Member - Oldplodder (QLD) - Saturday, Aug 04, 2007 at 21:15
"Will the brakes work without an electronic trailer brake control."- No.
"Which brand of electronic brake control is good we have looked at the Prodigy. "
Have one too for my CT. Find it works
255838
Reply By: Member - 'Lucy' - Saturday, Aug 04, 2007 at 21:35
Exactly the same as Old Plodder x 1000
You will be able to activate the brakes OFF or ON without a controller buts thats exactly what they will be:
Either 100% ON or 100% OFF.
255841
Follow Up By: rylie - Saturday, Aug 04, 2007 at 23:38
thanks
516990
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Aug 04, 2007 at 22:14
Hi rylie
The Prodigy is our best selling controller and followed by the Voyager.
You MUST have a controller for the trailer brakes to work.
It is also a legal requirement for trailers over 750kg to have working trailer brakes and that would also include a ADR approved controller if they are electric.
Derek.
255850
Follow Up By: rylie - Saturday, Aug 04, 2007 at 23:39
516991
Reply By: Member - JohnR (Vic)&Moses - Saturday, Aug 04, 2007 at 23:06
rylie, you don't actually say what sort of electric brakes you have or the type of camper. The electric brake system I have won't work with a Prodigy properly without a small hardware modification. Believe it shows errors.
255858
516989
Follow Up By: Gronk - Sunday, Aug 05, 2007 at 00:57
John, you have a KK caravan which I think is the 1st to have the electronic controlled brake system !!!
516996
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Aug 05, 2007 at 09:41
"KK caravan which I think is the 1st to have the electronic controlled brake system" is a bit more than I would have thought Gronk, but I am naive on those issues. I know it stops
well though if it is set high for priority. Known it to chirp tyres on dirt.
517015
Reply By: Member - Royce- Sunday, Aug 05, 2007 at 01:17
If you have a five pin plug you will probably find that the brakes are on-off-on-off as you indicate a right hand turn...
255869
Reply By: Member - Oldplodder (QLD) - Monday, Aug 06, 2007 at 07:56
To help a little more.
My last reply was a bit short. Not sure what level of knowledge you have.
Assuming only a little, this may also help.
Electric brakes usually work with a varying voltage from 0 to 12 volts.
0 off, 12 volts on hard.
A brake controller does this, and is usually activated off the car brakes.
Just did a brake check on my trailer and using the hand over ride, I could lock up the trailer brakes at 30km/hr at about 10 volts. My prodigy gives a read out of 0 to 12.
Bigger trailers will need bigger brakes and more voltage, hence most controllers have a variable setting control to get the right voltage to suit the particular trailer.
So you need something that you can change manually or also automatically to get the braking effect you want from the trailer.
Old brake controls were a one setting job, unless you changed the setting by hand as you braked.
Most systems now have some sort of G force sensor and increase braking of the trailer as the car brakes harder. Some sensors work better than others. This is part of the controller debate, which controller does this best :o).
Check the trailer to see if it has a small controller like a knob and dial on the A frame. One old fashioned way was a set and forget controller on the trailer. If it isn't there, the previous owner had a controller in the car.
256017
Reply By: AdrianLR (VIC) - Monday, Aug 06, 2007 at 10:37
The Prodigy is one of the few (only?) controllers that works in reverse which may be handy if you need to back down a slippery slope off road. Works
well with our Trak Shak (1100kg GVM). Should be around $400 fitted.
Adrian
256036
Reply By: Member - bushfix - Monday, Aug 06, 2007 at 10:51
G'day,
can highly recommend the Prodigy. Don't know what car you have but is an easy install on 95 Prado.
256041
