Waeco cf 80 mobitronics question
Submitted: Monday, Aug 06, 2007 at 17:58
ThreadID: 48468 Views:3546 Replies:4 FollowUps:4
Hi All
I have been running my Waeco cf80 thru the mobitronics & a double cig lighter plug i have installed in the back
Can i run it hard wired straight from my second battery to the mobitronics box or do i need to run it thru some sort of breaker ????? or something
when it comes to electronics i make a great chef lol
aussichef aka warren
Reply By: Mike Harding - Monday, Aug 06, 2007 at 18:54
The best thing to do with a cigarette lighter plug/socket is to destroy it with a large hammer :)
Your fridge probably has an internal fuse but it would be wise to use an in-line fuse between it and the battery this kind of thing:
http://www.jaycar.com.au/productView.asp?ID=SZ2016&CATID=23&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=552
will do the trick - put a 10 amp fuse into it.
Mike Harding
AnswerID: 256117
Follow Up By: Mike Harding - Monday, Aug 06, 2007 at 18:55
Hmmmm....
Jaycar part number SZ2016
FollowupID: 517221
Follow Up By: Member - Mike DID - Monday, Aug 06, 2007 at 22:03
Mike - when pasting product links from the Jaycar website you can delete "&CATID=23&keywords . . . . . " and it still works perfectly.
FollowupID: 517245
Follow Up By: Pajman Pete (SA) - Tuesday, Aug 07, 2007 at 07:46
Like this:
Jaycar Fuse
Pete
FollowupID: 517281
Follow Up By: Pajman Pete (SA) - Tuesday, Aug 07, 2007 at 07:50
I should have used the new "Preview Button"
This one should work
Pete
FollowupID: 517282
Reply By: Axel [ the real one ] - Monday, Aug 06, 2007 at 19:35
Ok , thing is that got it running thru the black box called a Mobitronics for the db50 motor in the Waeco , not too many people actually read the paperwork fully , your Mobitronics unit does NOT supply 12v when u have it plugged into 240v mains /gen ,,,, it supplies 24v to your Waeco 80lt, with the db50 99.9% of problems with Waeco is voltage loss ,thru lack of wire size and or volts , , you want to "hard wire " to your aux batt , your fridge will love it , just put a 30amp self reset circuit breaker inline close to the batt and use a min of 6mmsq wire pos and neg , NOT 6mm total but 6mm sq of wirestrand per.
AnswerID: 256128
Reply By: Olcoolone (SA) - Monday, Aug 06, 2007 at 19:56
Warren are you going to the YP4WDC monthly meeting on Sunday, if you are I will tell you then how to do it.
If you arn't message me and I will tell you over the phone.
Regards Richard and Lyn
AnswerID: 256136
Reply By: Member - Pesty (SA) - Tuesday, Aug 07, 2007 at 00:28
Hi Mate,
The best advice I can give you is to grab your mobitronics unit by the cord at the plug end and swing it around ya head at least 6 times whilestanding on the wharf, and let go at the right time while teaching it to swim.
Then get on the blower to jaycar and get a 12 amp 3 stage charger and hard wire that into the system at the same time as hard wiring your fridge for peak performance.
Forget the ciggy plugs.
Email me if you are still in trouble, as I will be inspecting the job next visit!!! LOL
Cheers pesty
AnswerID: 256184
