another question about towing a van with a commodore
Submitted: Tuesday, Aug 07, 2007 at 22:26
Robbg
Some may recall me recently asking about the need for a transmission cooler and heavy duty tow bar in order to tow a 1 tonne van with a v6 auto commodore
sedan. Thanks for the many responses. I've determined that my standard tow bar is rated to 80kgs ball weight and 1250kgs tow weight, and I've measured the ball weight of my van at about 90kgs (though this could be lightened by shifting the spare tyre and pole carrier to the rear of the van). A Hayman Reese distributor I spoke to suggested that a weight dist hitch on my current tow bar may be adequate to shift downward weight from the ball to the front of the vehicle (to get below 80kgs ball weight). Does this sound right?
Reply By: GerryP - Tuesday, Aug 07, 2007 at 23:26
Just trying to go through the physics of what you have been told. I can't see that a weight distribution hitch would make any difference to the actual weight on the ball, however, it would distribute the weight more evenly across the front and rear axles of the vehicle.
In any case, if it came to the crunch, the authorities would simply unhook the van to measure the downward force on the ball, so even it it did help, that's not how it's measured.
I would play it safe and reposition some of your cargo to the rear. However, take note that ideally, the ball weight should be around 10% of the total van weight. This means that you really need somewhere around 125kg on the ball. If the ball weight is too low, then you increase the chances of swaying and of having an unstable rig. I would definitely invest in a good Hayman Reece distribution hitch if you decide to go this way.
Is there an aftermarket or heavier duty towbar available that would increase the allowable ball weight? I would check with Holden and/or Hayman Reece as this would be a much safer option if there is something available.
Gerry
256343
Follow Up By: disco1942 - Wednesday, Aug 08, 2007 at 00:59
As Gerry said - ball weight does not change just because you install WDH - it just redistributes the weight between the
wheels. Add to that, the light weight tow bars are not really constructed to accept the extra stresses that WDH impose.
For safest towing, install a hitch receiver and WDH, and reload your van to achieve 10% ball weight.
517392
Reply By: MP - Wednesday, Aug 08, 2007 at 07:30
Hi Robbg, if you are going to be doing lots of towing I would spend the extra on a heavy duty hitch and weight distibuting bars. I saw first hand the effect of not enough weight on the ball when I followed the brother in law with his tandem axle van. Moved weight to the back of the van so the back of the vehicle was higher, travelled nicely until he got to around 80km/h and then it was all over the place. Towing heavy trailers is much more fun if it feels like it's not there and you can only see it in the mirrors.
Mark
256354
Reply By: gonebush SA - Wednesday, Aug 08, 2007 at 10:45
hi, we too tow a van with a auto v6 VT commodore with a trans cooler. the first thing we did was to buy a heavy duty tow bar, got it quite a lot cheaper through a wrecker, it was a genuine holden towbar with the weights it can handle on a plate on it, so we could make sure and not just guess it was right (cost only $95) that's with the wiring etc... a few weeks ago we took our car into an transmission specialist for a bit of work and we spoke to him about towing, he said that it is very important that we should use the power button and always tow in 3rd gear. he said it will not only tow better, have more fuel economy and the gearbox will thank us for it. he told us that towing in 3rd is the same gearing that the older cars use to have in top gear.
we weren't to sure about towing everywhere in 3rd gear but tried it out recently and it realy was better. the car certainly wasn't reving out like we thought it would, and going by the taco and everything else it seemed to like it.
good luck
256373
