LC 100 Electric radio aerial
Submitted: Wednesday, Aug 08, 2007 at 10:17
Treading Lightly
It's probably been asked before but here goes can just the mast be replaced if the nylon/plastic rack is broken? How do you retrieve the broken bit off the end of the rack?
JD
Reply By: Member - joc45 (WA) - Wednesday, Aug 08, 2007 at 11:29
Not sure about the Yota spares, but my Patrol broke the mast, and I was able to buy just the replacement mast, with flex nylon shaft inside it, with a rack on one end. Was about $80, compared with a few hundred dollars for the whole assembly.
A ripoff, but only way to fix it properly.
Gerry
256381
Follow Up By: Treading Lightly - Wednesday, Aug 08, 2007 at 11:45
Gerry.
Thanks for reply and info. When yours broke did you have to remove the broken bit of the rack or does it fall into the black hole somewhere?
JD
517428
Reply By: Andrew from Vivid Adventures - Wednesday, Aug 08, 2007 at 11:59
The procedure to install it is dead easy but you need a second set of hands.
1. you remove the chrome retaining nut off the top of the mast
2. switch radio on to extend the mast (this needs a second set of hands)
3. hold the mast fully extended and ask helper to turn off the radio - you just prevent it from retracting. Eventually the motor stops trying.
4. Have helper turn on radio and the mast will be expelled from the housing
5. insert the new cable in with the serrations facing the rear of the vehicle. Feed the cable until resistance is felt.
6. Have helper turn off the radio which will start the retraction of the new aerial. You might need to twist the cable slightly left or right to get it to grip the serrations.
7. As the cable retracts put the aerial mast into the hole and see that it retracts properly
8. put back on the retaining nut.
9. Have a beer with your mate.
CHeers
Andrew.
256383
Follow Up By: Treading Lightly - Wednesday, Aug 08, 2007 at 16:12
Andrew,
Thanks for info. If however the original mast and nylon rack is removed as per your instructions and it is obvious that some of the rack is missing (down the shaft or in with the motor) does one have to remove the motor to extract the broken bits?
JD
517463
Follow Up By: Andrew from Vivid Adventures - Wednesday, Aug 08, 2007 at 16:59
I'm not sure if you can get in that situation...
Gregory's says if the mast is extensively damaged use pliers to extract the mast... but the remnants of the rack should get driven right out of the housing.
I'm doubtful that the motor housing can be repaired easily... I know to replace it you have to replace the full cables to the stereo... but you could always try.
So, in all, me thinks you might be stuck... Have you tried putting in a new aerial mast?
Andrew.
517469
Reply By: me2@neuralfibre.com - Wednesday, Aug 08, 2007 at 17:11
There is a few factory varients, and the aftermarket masts only fit one (Areopro brand).
I got Toyota to replace my mast, they fitted for free, and only a little bit more than the aftermaket one that didn't fit.
Paul
256431
Reply By: Richard W (NSW) - Wednesday, Aug 08, 2007 at 18:24
I've had to replace two masts and did it by removing the wheel arch cover and unbolting the whole aerial assembly. Unfortunately the second time I found the aerial base bent as
well so bought a cheap rubber replacement aerial. I've still got the good replacement mast I didn't use.
256467
Reply By: apriti00 - Wednesday, Aug 08, 2007 at 21:35
I replaced my mast not long ago and yes I had to take off the plastic inner guard and remove the whole antenna. Once out I opened it up as the broken part remained inside, then it was a very simple operation once reassembled and as others have mentioned just needed to feed the new plastic section into the hole and operate the radio. Easy and painless.
256516
Follow Up By: Treading Lightly - Thursday, Aug 09, 2007 at 07:37
Thanks again to all you guys for all assistance. It looks like I will have to remove the motor assy, and take it from there. Another job for the weekend.
JD
517590
