1990 vx 80 series Turbo Diesel engine? What is it?
Submitted: Wednesday, Aug 08, 2007 at 12:38
Matt(WA)
Hi All,
Just a quickie, What engine is installed in the 1990 vx sahara 80 series? Its the 4.2 td(i have a 1hz in my 97 dx). Is it the 1hdt? What is the 4spd auto like? Found one cheapish that I can change over my 80 for for pretty much nothing and this is the sahara, with only 192K, front and rear diff locks, turbo diesel, auto and all the bells and whistles.
Thanks guys
Matt
Reply By: Member - Davoe (Nullagine) - Wednesday, Aug 08, 2007 at 12:47
Its the 1HD-T
basially 12 valve. Not as good as the later 24 vlave but still good apparantly and was the one that had th big end bearing problems. Not sure i it was a faulty batch or an ongoing problem others will know more.
Also willhave smallerbrakes than your 97 and can take 15 inch rims (not that youd want them)
never heard of probems with the 4 spped auto espeialy if it is the one that carried right through till fairly recently
256392
Reply By: Member - bushfix - Wednesday, Aug 08, 2007 at 12:53
yep, believe that would be the 1HDT replacing the 12HT. I believe the sludge box was pretty strong, from memory there were clutch problems with the manuals (related to the damper springs) causing a bad rattle.
check if the big end bearing issue was rectified in service history, there was a supplier issue and a bad batch got through.
i am sure some more knowledgable will chip in shortly
256395
Reply By: Axel [ the real one ] - Wednesday, Aug 08, 2007 at 16:34
Was a bad batch of bearings that by now would have made themselves known if in the vehicle your contemplating , however if you have even the slightest doubt get them changed not all that exy $$ and once done properly the donk goes forever , auto box is proven to be reliable , more so than the newer 5 speed auto especially if towing , , at 192k she's also just about due for a timing belt change [ every 1 hundred thou ]
256424
Reply By: 93 Navara - Wednesday, Aug 08, 2007 at 19:48
Matt,
If it's an Aus delivery, jump in. I'm a new convert to the 80 series, 90 model GXL with 1HDT. Pulls a treat and delivers economy of 12 to 12.5 litres per 100. From answers on this
forum, once you're bearings are changed over the motor has no major flaws. I got
mine to tow an outback hawk and it does it at the bit. Don't know if your current one is constant 4WD, but
mine needed the CVs done as there was a fair bit of driveline slack. An easy fix considering I thought it was the front diff.
Ben
256484
Follow Up By: Member - DOZER- Thursday, Aug 09, 2007 at 22:15
guys this model cruiser had the old hydraulic auto and they had heat issues, now the big end problems on these motors never goes away, so plan to do them every 100k/s which is a 500 job plus belt....mate has a 91 and three sets have came out bad like this....latest were acl berand. Lastly, if it is a jap import, be aware they have 24 volt starting not dual batteries as in what you see in oz.
517714
