Roof Racks
Submitted: Thursday, Aug 09, 2007 at 11:19
Coff
Hi all, I have a new 100 series TD landcruiser and am currently fitting it out. I cannot decide whether to go with a rackmaster slimline 2 metre or a ECB series 2 roof rack.
I like the idea of the rackmaster but do not know whether it will withstand the corrugations that I travel on regularly around central Australia. The rack will be used for mainly light gear (swags, tents etc) but may also carry a second spare from time to time.
Can anyone advise whether the rackmaster will withstand rough road conditions and whether it will make much difference in fuel economy compared with the ECB.
Another option is to remove the rack when not needed and would be interested in any comments on the removal of either rack.
If anyone has photos of a LC with a rockmaster fitted, I would also be interested in how it looks .....
Reply By: Peter 2 - Thursday, Aug 09, 2007 at 18:46
Can't really help with the actual roof rack but go very easy on whatever load you place in the rack as I've seen a few 100's that have cracked the channel in the roof where the rack mounts are. One had virtually no load in the rack whatsoever and never had according to the owner but had covered lots of rough country.
Also make sure that the bolt threads are coated with sealer when fitting as the
water will enter if you don't leading to rust and
water damage inside.
256633
Follow Up By: Crackles - Thursday, Aug 09, 2007 at 19:09
Gaday Pete. The cracks in the roof can often be attributed to the rack being too stiff not flexing when the car articlulates. The 100 series actually has a fairly high roof load rating compared to others.
Cheers Craig...........
517675
Follow Up By: Peter 2 - Thursday, Aug 09, 2007 at 19:16
Craig
I meant to say that the roof rack should be relatively flexible so as to not stress the roof structure.
I'll stick to the Humvee as I can actually walk around on the roof itself without scratching the paint or flexing the roof itself. CARC paint is unbeatable on a bush vehicle.
517678
Reply By: Crackles - Thursday, Aug 09, 2007 at 19:01
Gaday Coff. I have an ECB alloy rack on my Cruiser & can't fault it. Strong, light & makes no wind noise. I chose the hammertone finish which hides scratches
well & looks like new after 6 years. I regulary overload it on the big outback trips with tyres, fuel &
camping gear without issue. I occationally remove it leaving the 6 stainless brackets attached to the roof as they are sealed in & would be time consuming to reseal each time.
With a full rack bag it probably contributes to a 2mpg increase in consumption.
HZJ105 Vic
256638
Reply By: Coff - Thursday, Aug 09, 2007 at 22:01
Thanks Craig & Peter, you can't beat personal experience. I think I'll go with the ECB unless I hear from any rackmaster owners.
Coff.
256650
Reply By: Member - Shane D (QLD) - Friday, Aug 10, 2007 at 20:47
Hi Coff,
I have a rackmaster(oppie lock) on my 105 and I am real happy with it.
I have recently done 11000 kms cross oz via simmo and the old ghan line road to Alice, straight across center to Kalgoorlie and return to Bris with a quick look at
Vic high country and think that this would qualify as a good test.
I had my oz tent,complete 2nd spare on split rim,
camp table, highlift jack, and shovel mounted directly to rack and had no hint of trouble.
I bought the proper spare wheel attachment,as
well as highlift attachment and made my own shovel bracket and used the tracks that in built into the rack so that they where secured to the vehicle without using straps(except tent,
camp table).
These excluded items where attached with big black rubber straps thru eyelets that can mounted into rack in any position.
My not so skinny little frame(120kgs) can stand on one cross member with slight distortion,(remembering that the 100 series roof has a 150 kilo limit) leaves me thinking that if anything its over engineered (if loaded correctly) and user friendly not having to lift over sides,as
well as having virtually no wind drag(empty)and. . . . i'm raving aren't I
click on my rig pics and there's a photo there
Shane
dunno about ECB, not an agent for OL
256769
Follow Up By: Coff - Sunday, Aug 12, 2007 at 16:27
Thanks Shane, looks OK on a cruiser too.
Coff.
518062
