King Springs
Submitted: Thursday, Aug 09, 2007 at 11:39
ThreadID: 48555 Views:2137 Replies:5 FollowUps:1
Had a pair of these fitted to rear of 2006 GU Patrol ST cab chassis (coils) - since fitting ute leans to the left 22 mm (even with driver only) . Checked under & springs are fitted correctly & correct side . King springs have advised to swap them over ..... has anyone had similar issues ?
Reply By: bundyrulz - Thursday, Aug 09, 2007 at 11:52
G'day Lizard,
Just bought a 2000 GU wagon with a 5" lift. When talking to previous owner he said he had the same problem when he did the lift. The suspension workshop put different sized spacers on between the coils and body to even it out. Not sure if this is "the way to do it" but just letting you know what happened. BTW, the wagon drives superb.
Bundyrulz
AnswerID: 256583
Follow Up By: Member - Glenn D (NSW) - Friday, Aug 10, 2007 at 10:30
Dameon ?
FollowupID: 517763
Reply By: Gronk - Thursday, Aug 09, 2007 at 13:31
Try swapping them over to see if they maybe marked the springs wrong !!
If it doesn't fix it. send them back....found they are good to deal with and claim they stand by their product..
AnswerID: 256589
Reply By: Skippy In The GU - Thursday, Aug 09, 2007 at 17:34
I've had a problem with my old GQ , they replaced it but within a year it sagged again.
I know others that have had problems within a week and King Springs won't fix it because it was over 2"
AnswerID: 256624
Reply By: Grungle - Thursday, Aug 09, 2007 at 19:00
Have had 5" king springs fitted for a few years and mine have sagged around 1.5" to 2" on drivers side. Wasn't sure if this was due to a conversion to a TD42T or what but am due to replace. Not sure if I will go back to King.
David
AnswerID: 256637
Reply By: Member - JASON C (WA) - Friday, Aug 10, 2007 at 02:23
hey lizard, had the same on my GU with 3 inch raised king springs sitting lower on the drivers side. ended up putting a 15 mm spacer to even it up, I thought because the sub tank is on that side thats why it was a fraction lower .
AnswerID: 256665
