Opinions on Different Exhaust Jack Brands
Submitted: Friday, Aug 10, 2007 at 14:24
Sam Wolyniec
Hi all,
I am info gathering about an appropriate exhaust jack.
I was wondering if those of you who have used one or more exhaust jacks could make some comment as to which brands you think are the best.
To give some context of my situation, I have a Hilux Surf, and do a lot of weekend work/play on beaches, mudflats and near creeks in the North-West. I often go with a Nissan Patrol, who is bog-prone.
Any comments very appreciated.
thanks,
Sam.
Reply By: Member - Peter G (NSW) - Friday, Aug 10, 2007 at 15:01
SAM.
What ever brand you get make sure it has an air attachment in it for fine tuning with your air compresser.
PETER.
256727
Follow Up By: Sam Wolyniec - Friday, Aug 10, 2007 at 16:15
Thanks Peter.
I would've thought i would only use the exhaust. Do you prefer to use a compressor?
517804
Follow Up By: Member - Kiwi Kia - Friday, Aug 10, 2007 at 16:39
What brands have such a fitting ?
517807
Follow Up By: Member - Troll 81 (QLD) - Friday, Aug 10, 2007 at 16:58
Mine that I got from ARB does have a valve that I can run from the compressor...takes way to long though
517816
517817
Follow Up By: Scrubcat - Friday, Aug 10, 2007 at 19:11
Rays Outdoors had Bushranger x Jack for $181.00 at there 26% off sales in Vic last few weeks, these have a valve fitting for a compressor. I don`t know if they have stores in your area.
I got a Bushranger Maxi air Compressor from them for $288.00, best price I have seen after a long time looking.
Scrubcat
517843
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 08:56
So this Bushranger X-jack works
well?
THis seems to be the most common one that 4WD drive shops are selling in
Perth.
517884
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 09:04
To Rob S - I rushed down to the newsagent and got the current edition of 4Wd Monthly - but couldn;t see any review - do you mean the August edition?
517886
Follow Up By: Kev M (NSW) - Saturday, Aug 11, 2007 at 09:36
Sam,
The review is in the 4WD Monthly Gold Label Edition. 4WD Accessory Handbook. Vol 4 No.3
Hope that helps.
If you cant find a copy let me know and I'll scan the report and email it to you if you like.
Cheers Kev
| Russell Coight:
517893
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 09:44
Thanks Kev,
I would really appreciate that. I work in an area where the magazine selection is a pretty limited.....
Can you see my email address?
samwolyniec@gmail.com if you cant...
Sam.
517894
Follow Up By: Kev M (NSW) - Saturday, Aug 11, 2007 at 09:59
Sent
Cheers Kev
| Russell Coight:
517896
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 10:06
THanks again - but the resolution was too low to read the text. Is it possible to increase the detail of the scan?
517898
Follow Up By: Kev M (NSW) - Saturday, Aug 11, 2007 at 10:20
Sam,
Increase the image size and it will be able to be read, I had decreased the image sizes to reduce the size of the email that I had sent. If you still have problems I'll send them full size
Cheers Kev
| Russell Coight:
517901
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 10:23
ok - i'll have a play around and see how i go.
517902
Follow Up By: Kev M (NSW) - Saturday, Aug 11, 2007 at 10:48
Sam,
Look at these
| Russell Coight:
517903
Reply By: Member - Shane D (QLD) - Friday, Aug 10, 2007 at 20:01
What ever brand you get it work heaps better off a diesel motor than a petrol(still work
well),but a compressor? may come in handy if bogged and no motor,but you will find that it will take awhile to inflate.
I bought an exhaust jack from a autoparts outlet,saved heaps compared to a brand name,till I put it under the cruiser, all my so called friends got a good laugh that day when it could just reach the chassis,let alone lift
wheels off the ground,still, it comes in handy if badly stuck and if the chips are really down,its expendable
Shane
256762
Follow Up By: Sam Wolyniec - Saturday, Aug 11, 2007 at 09:01
ok. I;ve got one of those late 90's 3Lt turbo diesel auto Surf that get imported from japan by the bucket load (you've probably seen hundreds of them floating around).... so the diesel part of no probs for me.
Good point about a 'no-name' jack, I'd rather spend a bit of moeny and get the right brand. THe X-jack seems to be the most common.
517885
Follow Up By: Skippy In The GU - Monday, Aug 13, 2007 at 08:24
I've heard it isn't good to use them on cars with Turbo's
518153
Reply By: Shaker - Saturday, Aug 11, 2007 at 12:49
They are very hard to use with angle cut tail pipes, I had a short piece of exhaust pipe flared to fit over the angled end & just slip it over when I use the bag, which fixed the problem.
256809
Reply By: Brooka27 - Saturday, Aug 11, 2007 at 21:23
Are you heading to
Port Hedland?
Regards Jason Brooks
256871
Follow Up By: Sam Wolyniec - Monday, Aug 13, 2007 at 12:36
Yeah im working up there.
518182
Reply By: Member - Alex K (NSW) - Sunday, Aug 12, 2007 at 21:57
From my limited experience with air jacks... too much hard work and risk involved. Trying to find a place under my LC80 which was flat, not hot and not sharp was near impossible. I found it very difficult to ensure the bag inflated without bending over on itself. Additionally, doing it by yourself is no easy task. I don't travel along or at least where others aren't and would always prefer a snatch than getting the bag out. Don't forget with the use of an air bag you're still on the sand/mud that got you into trouble in the first place (only hopefully now with compacted sand under the tyres), very easy to get suck again. Go the snatch, particularly if you're travelling with a Patrol.
Just my 2 cents
Alex
256980
Reply By: Member - Peter G (NSW) - Monday, Aug 13, 2007 at 11:47
Hi Sam
I have been away for a few days and was surprised to read so much diverse thinking about exhaust jacks.I have a Bushranger Xtream.I paid top price , but you get what you pay for,no sense carrying something around with you for years then have it let you down when you need it.I suggested the air valve as a fine tune adjustment.I use the exhaust like everybody else, but find the problems stated by others can be over come by taking your time and using the compressor ( good quality again) to position the jack how I wont it then give it a blast with the exhaust. I purchased mine after been bogged in mud on a mates
farm. I was on my own and only had a Toyota wind up jack.(but that's another story) It's times like that the air jack is handy. If you are with somebody else use a snatch strap but slow down and enjoy the moment.
257042
Follow Up By: Sam Wolyniec - Monday, Aug 13, 2007 at 14:21
Hey Peter,
Yes i think i agree with you, better to go for something quality.
I have called a 4WD
shop in
Perth, they;ve quoted me $359.00 for the Bushranger X-jack, which i think is the one you;re referring to.
What happens when the X-jack is fully inflated? is there some valve on it to release excess pressure?
I have some no-bread heavy synthetic rope with metal hooks either end i bought from a service station somewhere a long time ago which serves as a cheap substitute to the snatch strap.
Sam.
518190
Follow Up By: Sam Wolyniec - Monday, Aug 13, 2007 at 16:59
no-brand
518207
Reply By: Geoff (Newcastle, NSW) - Monday, Aug 13, 2007 at 14:45
Hi Sam,
Another vote for the Bushranger X-Jack here.
I do a lot of
beach fishing and am typically on my own and in the middle of the night.
Mine has come to the rescue two or three times when i've been half asleep on the way
home and got myself bogged.
Very useful item in conjunction with a shovel, jack the vehicle. Fill the hole, let it down and then engage driving brain.
Geoff
| Geoff,
257064
Follow Up By: Geoff (Newcastle, NSW) - Monday, Aug 13, 2007 at 14:48
Oh, I always carry a couple of squares of old carpet about a metre by a metre.
One on top of the Jack to prevent sharp and hot chassis bits puncturing the bag. One under it to prevent sharp objects on the ground doing the same thing.
Geoff
| Geoff,
518194
Follow Up By: Sam Wolyniec - Monday, Aug 13, 2007 at 14:54
Good advice thanks. Currently i am a bit wary when i go out on day trips with one car... this should allow a bit more range.... agreed on the carpet.
518196
