pajero fuel pump
Submitted: Friday, Aug 10, 2007 at 21:51
ThreadID: 48600 Views:4112 Replies:6 FollowUps:4
G’day
Has anybody had a problem with fuel injection pump with a pajero DID.
We were on our way back from cape york almost made it home then the engine stopped while doing 100km on the highway, the electronic fuel pump had to be replaced (the immobilizer switch from what I can make out)
Reply By: jon p qld - Saturday, Aug 11, 2007 at 07:25
Most of the new electronic fuel pumps are very prone to water damage, as in water in fuel. I haven't had to replace a Pajero one yet but have replaced numerous Patrol ZD30 pumps and also Rodeo's. It's not a cheap job either !!
AnswerID: 256790
Follow Up By: jonl - Saturday, Aug 11, 2007 at 08:49
is there a fuel filter that will take out the water?
FollowupID: 517882
Reply By: Member - DOZER- Saturday, Aug 11, 2007 at 15:29
I have heard on here b4 that running a paj did out of fuel blows the pump aswell....so a blockage in the lines due to algai would do thesame im guessing....and algai comes from water in fuel....make sure you get those lines checked thoroughy...and use some algai treatment to be sure.
AnswerID: 256816
Follow Up By: Member - Scoof (SA) - Sunday, Aug 12, 2007 at 22:22
Dozer I havent heard about running a paj out of fuel blows the pump , are you talken DiD .I have done it a few times and so far all is good.
May be I shouldn't do it anymore??
Cheers Scoof..
FollowupID: 518131
Follow Up By: Member - Scoof (SA) - Sunday, Aug 12, 2007 at 22:23
Cheers Scoof..
FollowupID: 518132
Follow Up By: Member - DOZER- Monday, Aug 13, 2007 at 07:06
A search thrugh the arcives should find the post...maybe the person who had to buy a new pump was just a one off...its impossible to draw conclusions from one occurance, and your experience seems to blow that conclusion out of the water..
FollowupID: 518147
Reply By: jonl - Saturday, Aug 11, 2007 at 16:20
That might have been some of the problem as the fuel was very low when it stopped. (fuel light was not on)
AnswerID: 256821
Reply By: marq - Saturday, Aug 11, 2007 at 16:24
TIme to get a long range fuel tank 81L from LRA are good.
AnswerID: 256822
AnswerID: 256823
AnswerID: 256824
