In-car charging both wet and AGM batteries
Submitted: Sunday, Aug 12, 2007 at 11:12
ThreadID: 48633 Views:3879 Replies:8 FollowUps:15
AGM batteries require a higher charging voltage than wet (cranking) batteries. Has anyone got an easy way of providing the higher voltage for an AGM auxilliary battery, when charging from the same alternator/regulator which charges the cranking battery?
J and V
- Albert Einstein
Reply By: Member - bungarra (WA) - Sunday, Aug 12, 2007 at 11:31
Gidday
we have AGM batteries that couple via a VSR..... from the standard alternator....... that is charging the cranking batteries.
Never had a problem in getting our AGM's charged...and our system has worked well for years...based in my experience I think you are being concerned over a situation that may be needless......
the biggest issue in charging is about choosing the correct cable size and relay...isolating solenoid....whatever else you choose for batery isolation when stationary.
VKS 1341
AnswerID: 256917
Follow Up By: Member - John and Val W (ACT) - Sunday, Aug 12, 2007 at 11:43
Thanks Bungarra - you may well be right that I'm jumping at shadows. But on a recent trip I found that on no-travel days the solar panels which are limited to 14V, provided a lot more charge to the AGM battery than the alternator (which is capped at 13.2V) does when travelling.
I certainly agree that cable size is critical, and of course a suitable isolator.
J and V
- Albert Einstein
FollowupID: 518029
Follow Up By: Gerhardp1 - Monday, Aug 13, 2007 at 10:14
13.2V is pretty low for a charging voltage. I think you should get this beefed up to at least 13.8V
I have an AGM under the bonnet of the Jackaroo and also one in the Camper Trailer - I have no trouble charging both fully. The Alternator output is 14.0V and very occasionally will show 14.2V for a few seconds.
FollowupID: 518170
Reply By: Member - bungarra (WA) - Sunday, Aug 12, 2007 at 12:00
Hi John
Yes I agree that the solar panels punch the charge in when compared to the vehicle alternator........we are also solar independant and rely heavily on them to bring the batteries up to capacity......... You should be getting 13.8v at least from your alternator however.
After an overnight camp or some overcast days followed by a days driving we have found that the amps pushed in by the vehicle alternator is less then therotical expectations....
on our camper trailer we have installed a Plsamatronics PL20 to control our solar input and battery management......we draw from 2 AGM 100ah batteries......we route the alternator charge through a shunt so as to allow the PL20 to monitor both the draw and either charge inputs (solar and alternator) ...in doing this the PL20 allows for battery amps in and out regardless of charge source..this is working well for us
regards
VKS 1341
AnswerID: 256921
Follow Up By: Member - John and Val W (ACT) - Sunday, Aug 12, 2007 at 12:13
Sounds like our systems are pretty similar. I use a voltage sensing relay to switch the alternator onto the auxiliary load line, and a solar controller to manage the solar input, restricting charge voltage to 14V and connecting also to the load line. This line then runs through a 0.01 ohm shunt to the batteries. Voltage and net current are metered.
I'm interested in your comment that the alternator should be delivering at least 13.8V. That seems a bit high to me, though it's an easy solution to my charging issue provided it doesn't fry the cranking battery.
J and V
- Albert Einstein
FollowupID: 518033
Follow Up By: disco1942 - Sunday, Aug 12, 2007 at 20:33
FollowUp 1 - "I'm interested in your comment that the alternator should be delivering at least 13.8V. That seems a bit high to me," 13.8V is not too high for an alternator output. This voltage is for a vehicle when it is thoroughly warmed up (more than 1/2 hour running.) When the motor is started for the first time of the day 14.3 - 14.5V should be expected. These are the voltages both of my discos produce. The two Hiluxes I had prior to the Discos had slightly lower voltages as they did not have Calcium/calcium batteries like the modern vehicles.
FollowupID: 518109
Reply By: Member - bungarra (WA) - Sunday, Aug 12, 2007 at 14:21
Hi again
yes our systems seem very similar.....the charge voltage of 13.8 is normal.....in fact my VSR is factory programed to kick in at 13.7 and out at 12.8......no means of changing the default...and I have verified these V with multi meters.
might pay you to check at the other end of the cables immediately prior to the auxillary battery input with a DC clamp meter for the amps and compare the reading to the display on your controller.... also multi meter at the auxillary battery end for V and see what you have happening
regards again
VKS 1341
AnswerID: 256935
Follow Up By: Member - John and Val W (ACT) - Sunday, Aug 12, 2007 at 17:05
Hi Bungarra - Thanks for your further comments. The voltages and currents I refered to are those at the Aux batteries. I have heavy wiring throughout (2x 6mm**2 cables in parallel). Current is measured as the voltage across a big calibrated 0.01 ohm resistor.
Been doing some Googling which has confirmed your 13.8V charging voltage as normal for a standard lead acid battery - clearly my 13.2 is too low. (In fact it seems that the acceptable range is about 13.5 to 14.5V) Differences in battery chemistry can call for higher charging voltages, some batteries (eg lead/calcium) may require nearer 15V.
This is a complex area and it may be better for me to leave it alone. My system is working, though not optimally. If it's not broke, don't fix it!
J and V
- Albert Einstein
FollowupID: 518065
Follow Up By: Member - Mike DID - Sunday, Aug 12, 2007 at 20:54
There are 2 voltages specified for Battery Charging
1. The Float voltage is what can be applied to the battery permanently without overcharging. This is normally 13.6 to 13.8.
2, The Cyclic voltage will charge the battery faster but will cause overcharging once the battery is full. This is normally 14.2 to 14.6.
These voltages need to be reduced if the battery is above 30 degrees - as it would be in an engine compartment (60 degrees in summer)
Calcium-Calcium batteries need higher voltages than these ones above.
FollowupID: 518115
Reply By: Robin Miller - Sunday, Aug 12, 2007 at 17:05
Hi John
First I think also that basically this shouldn't be necessary and if you have a modern alternator that isn't putting out 14v minimum on start up dropping to 13.8 when hot then problem is there.
The easy solution is to generate higher voltage cheaply.
To do this aquire a laptop car charger which cost 30-$50 from places like jaycar and come in 3 & 6 amp sizes.
assuming 6 amp version , set its output switch to 15v
I.E. with 12v input it will output 15v at 6amp , which is more than a 60w solar array.
Your AGM battery should be fine with 15v when driving the car,
and charge is not permanent. If your intend for permanent operation a 10amp diode in positive lead will drop volts of charge to around 14.4
An issue this cheap system is that if your battery is down then it will initially draw more than 6 amp and blow the laptop converters fuse.
A 1/2 ohm 10watt resistor in line with positive wire is usually all you need to solve this issue, or if agm is a long way away charging it via thin leads will often do. Your might need a little experimenting here so keep a couple of spare fuses , or if you provide details I could suggest best in your case.
Robin Miller
AnswerID: 256946
Follow Up By: Member - John and Val W (ACT) - Sunday, Aug 12, 2007 at 17:17
Thanks Robin,
I considered using a switchmode supply as you suggest, but the only affordable ones won't supply more than 6 amps, which isn't much for a pair of 100 Ah batteries. I'll talk to the local auto electrician and see if he has a way of tweaking up the voltage a bit. I can invent something on the regulator's sense line to trick it into providing a bit more voltage but thought it worth asking here if anyone had gone up these paths.
Thank you for your thoughts
J and V
- Albert Einstein
FollowupID: 518067
Follow Up By: Robin Miller - Sunday, Aug 12, 2007 at 17:56
Hi John
You can add a diode in the field circuit and get alt to put out 0.6 volts more if you don't mind messing around with that stuff.
I was just giving you the non-playing around solution - 6 amps works well for me.
Robin Miller
FollowupID: 518076
Follow Up By: Member - John and Val W (ACT) - Sunday, Aug 12, 2007 at 18:22
Hi Robin,
I appreciate your thougts. Mine went along the same lines initially. One problem I have is that I already have a lot of gear running off switch mode supplies and the electrical noise is pretty horrible. I have to turn everything off to run the HF radio for example. My present plan is to look at the effect of putting a diode drop in the sense lead to the regulator. This should encourage it to push the alternator up at least 0.6V - the alternative seems to be a replacement alternator since the present one (and its internal regulator) are not delivering.
J and V
- Albert Einstein
FollowupID: 518082
Follow Up By: wheeleybin - Sunday, Aug 12, 2007 at 19:43
Hi Im confused.
A normal flooded wet cell battery cranking of otherwise can be charged at 14.8V most AGMs and sealed non maintenance batteries charge at 14.4V along with some Gel and AGM (USA)only charging around 14.2V.
The statement that an AGM needs a higher voltage than a FWC does not appear correct as most AGM,s are voltage sensitive and if you charged them at higher than FWC voltages you could damage them.
If you have your solar reg set at 14V your are throwing .4V from the panel away in heat and taking longer to charge your battery as the higher the volt the quicker the charge time.
A good smart charger with temperature compensation will allow you to charge faster and safer.
Ian
FollowupID: 518099
Follow Up By: Robin Miller - Sunday, Aug 12, 2007 at 21:59
Hi Ian
Its pretty easy to get confused with this stuff unless the conditions are spelled out and the same.
The key issue here is that we are charging from a more or less constant voltage source , not from a controlled 3 stage type charger.
From alternator the 14.8 is to high to be constantly applied to your average car battery and will cook it, whereas AGM batteries are fundamently more voltage tolerant. This is because batteries should only be charged at volts up to there gassing volts and AGMs by definition have a less defined gassing point, with most not gassing at all in normal use.
The above is a seperate issue than what is required to charge them most efficently.
Robin Miller
FollowupID: 518127
Reply By: Mainey (WA) - Sunday, Aug 12, 2007 at 19:49
Simple solution IF you have an EXTERNAL (Alternator) Regulator is to replace it, (about $40) for a higher rated one, I'm not sure if it's the same for internal mounted regulators.
My 55 amp alternator now runs @ 14.4v at idle when initially charging the Calcium "Cranking" (5 yo DC27 Delkor Deep Cycle) battery, the 2 x 115ah AGM DC's never get below 12v, even when actually powering the fridge at night, so they never take long to recharge next morning under any conditions.
When the sun's shining and the fridge is running, there's more power going into the battery than being used by the fridge, so the battery is always fully charged till the sun goes down, unlike using a gennie, the AGM's only loose power when running the fridge at night.
The 2 x AGM DC's are charged by 200 Watts (~17v) of Solar power on the roof 24/7 via a 3 x stage solar regulator and they still read 12.7v just prior to the fridge starting up in the mornings, before the sun is up - when still almost dark, the fridge only runs 3 or 4 times a night for ~20 minutes.
AnswerID: 256960
Follow Up By: Mainey (WA) - Monday, Aug 13, 2007 at 11:58
I have looked this morning, just after daylight, the Steca Solar regulator shows the "State of Charge" of the AGM's @ 97%, 13.0v, with 2 amps going to the Aux batteries, fridge was 3.7 degrees so had not run for a while.
UN-fortunately the "Cranking" battery was only showing 12.5v so when I cranked the motor to 'test' it, it started but was a bit 'slo' so obviously the "Cranker" is on it's way out, after 5 years that's about $28 year so I'm not unhappy :-))
Connected it in parallel with the AGM's so the Solar system will recharge it today and I will replace it in the next few days.
Contacted 'some-one' about an Extreme and was informed they now retail at $200 so will go up to Perth and pick up a decent battery myself - and spend the 100 on something else.
FollowupID: 518177
Reply By: drivesafe - Sunday, Aug 12, 2007 at 21:32
Hi John and Val, as pointed out above, the first thing you need to do is have your alternator/regulator checked out.
For a while a number of vehicles were produced with alternator voltages that started out at something like 14 to 14.2 volts and once at operating temperature, dropped to around 13.8. This 13.8 is the minimum charging voltage needed for most batteries to be able to charge properly.
Newer vehicles are now being equipped with alternator voltage outputs of anything up to 14.7, with the average vehicle voltage being between 14 and 14.2, so your vehicle’s voltage is way below even the lowest charging voltage needed.
Next, unlike ordinary flooded wet cell and even the average gel cell battery where the info for one brand pretty well is the same for all other brands of similar batteries, every AGM battery is DIFFERENT and you must have the exact info for your specific brand and type of AGM battery.
Most AGM batteries are NOT specifically designed for automotive use but were originally designed for use in RAPS and UPS set-ups and as standby batteries for starting stationary generators.
As such, very few AGM batteries can tolerate more than 14.8 volts ( amongst other potential problems associated with using them in automotive applications ) so check out the info for your batteries as well.
Cheers.
AnswerID: 256977
Follow Up By: wheeleybin - Monday, Aug 13, 2007 at 07:42
Sorry Drivesafe but AGM batteries were originally designed and built for the US Army use in military vehicles and most of them are intollerant to voltages over 14.4V.
Other AGMs claim to to have acceptance to voltages up to 14.9V but do not have the same level of recombination technology and cannot accept high amperage input and if you have high amperage input at over 14.4V you can damage them.
Gel Batteries vary in voltage acceptance depending on manufacture with some USA only accepting 14.1V and others accepting 14.4V.
The only battery that can accept a voltage higher than a Flooded Wet Cell is a Calcium.
Sales guff is so confusing on batteries and we are all led up the garden path by battery salesmen that appear to only know what is on the sales brochures themselves.
FollowupID: 518150
Follow Up By: drivesafe - Monday, Aug 13, 2007 at 08:24
I was not referring to AGM battery history but to present day manufacture techniques.
As I pointed out, ANYONE contemplating or using any AGM batteries should check the specs for their specific battery and not take notice of any generalised info relating to AGMs as there are as many different specs for AGM batteries as there are AGM battery manufactures.
There are also only a very few AGM batteries that are specifically designed and manufactured for automotive use, such as some of the Optimus and Oddysseys.
Don’t work on generalised info that you get from sale personal or on the net, go and get the exact info you need direct from the manufacturer of your specific battery.
I don’t sell batteries so I have no advantage to be gained by pushing one type of battery over another but I do manufacture equipment for use with all forms of batteries and in many cases, people are forking out loads of money for high end type batteries when, in MANY cases, ordinary flooded wet cell batteries will do the same job just as well and for a lot less, plus because they DON’T need special charging regimes, save additional money on not having to have special charging equipment.
FollowupID: 518154
Reply By: Member - Roachie (SA) - Sunday, Aug 12, 2007 at 22:19
My system works great.
I have 2 sealed lead acid batteries joined in parrallel for starting and running the "standard" stuff.
Then I have a 120a/h Fullriver AGM which is charged by an Arrid Twin Charger @ 20 amps. It's like a normal battery charger, but only requires 12 volts or so and "FULLY" charges the AGM.
AnswerID: 256985
Follow Up By: Mainey (WA) - Monday, Aug 13, 2007 at 12:22
The Arrid twin Charge works terrific when actually situated in the Camper Trailer or Caravan adjacent to the "storage batteries" as it eliminates voltage loss due to the excessive distance from the power source (Alternator)
However- 'IF' sufficiently sized battery cable is used to the external 'storage battery' this will also eliminate voltage loss - only if the Alternator/Regulator is capable of supplying the required current for the "storage batteries" in the CT or Caravan, which appears to be the problem in most cases.
FollowupID: 518179
Reply By: Member - John and Val W (ACT) - Monday, Aug 13, 2007 at 20:25
Thank you everyone for your input. This is obviously a complex area. Your detailed comments indicate what a valuable pool of expertise and experience lies within this forum.
Thank you
J and V
- Albert Einstein
AnswerID: 257123
