Manual boost controller zd30
Submitted: Sunday, Aug 12, 2007 at 16:19
ThreadID: 48639 Views:31170 Replies:2 FollowUps:6
Question for Chaz, My boost gauge come of after the intercooler and I am concerned about the pressure drop accross the intercooler. If I run 18# boost through the dawes valve will that be the same as running 22# from before the intercooler. If so should I only run say 15# boost after the intercooler. Any feedback will be welcome
Thanks Dave
Reply By: Eric Experience - Sunday, Aug 12, 2007 at 20:44
The pressure drop will be proportunal to the RPM squared so the question has no simple answer. Eric.
AnswerID: 256969
Reply By: Chaz - Monday, Aug 13, 2007 at 05:53
Hi Dave,
We only use these pressures as a guide. I personally doubt if you would have any noticeable difference in pressure before or after the cooler, but this can depend on any restriction in the cooler. Having the gauge fitted after the cooler will give you a truer indication of what’s going into the motor, but a good non restrictive cooler should do the same. Also you could find similar differences between two different boost gauges.
Depending on whether you’re tuning for performance or durability will determine your setup. I’ll presume durability, so the important thing is to limit your maximum boost to around 18psi @ 4000rpm. Then adjust the needle valve to limit boost to 6psi @ 1500 and about 10psi @ 2000rpm. From 1500 rpm your boost should be linear to 16psi @ 3600rpm. This is the ideal boost curve because the ZD30 makes maximum power @ 3600rpm and it makes no more over 16psi.
After fitting the manual controller and bypassing the VNT control solenoid, you’ll find that boost is mainly determined by engine rpm and not so much by load. This is better for turbo and engine life although there is now a compromise between boost and EGT’s. If your EGT’s are too high, you should increase boost slightly at lower rpm.
Chaz
AnswerID: 257006
Follow Up By: DJS - Monday, Aug 13, 2007 at 09:32
Thanks Chaz,
That is the info I was after, will be installing as soon as dawes valve arrives.
Thanks Dave
FollowupID: 518163
Thanks Chaz,
Thanks Dave
FollowupID: 518164
Chaz,
Thats the info I was after, will install as soon as I get a chance.
Thankyou very much, Dave
FollowupID: 518165
Follow Up By: DJS - Monday, Aug 27, 2007 at 11:45
Chaz,
Everything has arrived,but some more questions. Did you bring the vacumn line of the reservoir or straight from the pump? And did you run the bleed line back to the air cleaner or put a small filter under the dash?
Thanks Dave
FollowupID: 520500
Follow Up By: Chaz - Monday, Aug 27, 2007 at 12:45
Hi Dave,
Depending on the year/model of your car, the vacuum reservoir could be different, but I ran the vacuum line that went to the solenoid from the pump, over to the dawes valve. Earlier ZD30’s had the reservoir on the motor and later series 3’s had it mounted to the left side. I don’t think series 4’s used one.
I ran the bleed line back to the resonator that is attached to the air filter. The small green damper/filter was then used in the vacuum line and placed near the dawes valve. I did this to slow down the vacuum signal and stop any impurities getting back to the vacuum pump.
All the hoses that I used went to the solenoid, so after it’s fitted there shouldn’t be any left at the solenoid. I fitted a loop and plug to block off the solenoid ports and stop any debris from getting in.
I ran two hard plastic lines, like the ones you would use on a VDO boost and oil pressure gauge (1/8” or 3mm) through the firewall and into the cab for the needle valve. The small rubber tube slides easily and firmly over this to give a good seal.
I hope this all makes sense, but look HERE for some pictures of my setup.
All the best and let me know if I can help.
Chaz
FollowupID: 520507
Follow Up By: DJS - Wednesday, Aug 29, 2007 at 17:26
Thanks again Chaz,
Will let you know when I've got it sorted out.
Thanks Dave
FollowupID: 520892
