Wheel Bearing Repack
Submitted: Thursday, Aug 16, 2007 at 21:49
ThreadID: 48775 Views:4351 Replies:10 FollowUps:4
A while back I saw mention on this site of a tool for injecting grease into wheel bearings during a repack.
Can anyone tell me where I can get hold of one.
Also what is the recomended distance between repacks. I inspected mine today (75 series Troopcarrier, 20k since last repack) and found water and dust had got in and the grease had turned to a brown mess and the bearings were shot. We were in the Kimberley June and July with that out of season rain, which could have contributed to the problem.
Thanks for any advice
Reply By: AndrewX - Thursday, Aug 16, 2007 at 21:56
Just pack the grease into the bearing by hand Michael and replace all seals - rain in the Kimberley should not cause bearing failure!
AnswerID: 257576
Reply By: Member - Luke (SA) - Thursday, Aug 16, 2007 at 21:57
Any auto parts store should sell them
I do them with my hands because I find I get just as much grease on them either way I do it.......... ok and I'm a tight arse and wont buy one lol
Cheers Luke
AnswerID: 257578
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Thursday, Aug 16, 2007 at 22:01
Vigorous working in with the hands is the way to go
AnswerID: 257579
Reply By: Member - Doug T (Qld) - Thursday, Aug 16, 2007 at 22:12
Snap-on Tools
AnswerID: 257582
Reply By: Member - Doug T (Qld) - Thursday, Aug 16, 2007 at 22:22
The Snap-On Grease Injection Needle
AnswerID: 257583
Follow Up By: Mr Fawlty - Friday, Aug 17, 2007 at 13:09
Doug, this looks suspiciously a bit like the gadget that a Dr inserted into my left knee joint to put some grease in to stop the bones grating.....
FollowupID: 518926
Follow Up By: Member - Doug T (Qld) - Friday, Aug 17, 2007 at 18:02
Well you don't have to tell everyone .......lol
FollowupID: 518968
Reply By: Member - Reiner G (QLD) 4124 - Thursday, Aug 16, 2007 at 22:26
There is one listed on -bay item number 290150444457
I do mine by hand and I think it's quicker.
Reiner
AnswerID: 257584
Reply By: cowpat - Thursday, Aug 16, 2007 at 22:35
Toyota recommend 20,000 km. Some prefer 40,000 km as that is normally sufficient. I do 20,000 km as I can afford it.
I've had the brown sludge problem in the rears of my LC105. Probably water crossings. I now use Castrol APXT grease (the blue stuff, water resistant) and pack it in by hand. I put plenty in the hubs, not much air space left when I'm done and I haven't had any ill effects. Some would say this means more drag = worse economy but I reckon there are plenty of losses elsewhere and more grease = less water can get in.
Also, always new hub seals, and I run a generous amount of marine grease (sticky dark green Shell stuff) on the hub seals and on the surfaces of the stub axles where they run.
Also, if there's signficant wear on the stub axle sealing surface, fit Speedi-Sleeves. Casper
AnswerID: 257587
Follow Up By: cowpat - Thursday, Aug 16, 2007 at 22:37
And wear latex throw-away gloves for packing in the grease. No need to clean up your hands afterwards.
FollowupID: 518868
Follow Up By: Michael46 - Friday, Aug 17, 2007 at 21:38
cowpat
Thanks for the tip on Speedi-Sleeves there is a small groove on the stub axle caused by the grease seal. I think the water was getting in between the the axle flange and hubs not sealing correctly.
FollowupID: 519018
Reply By: Member - Duncs - Friday, Aug 17, 2007 at 08:23
I like to pack mine by hand for a number of reasons.
I know I get them well packed.
It takes a while but I find that when my hands are covered in grease that I get a fair amount of peace from the mum and kids.
I like the idea of latex gloves but I do it with bear hands because I can feel if there is any grit in the grease. A good supply of rags is essential. I keep the greasy rags out of the dirt and use them for wiping thigs over before putting it all back together. The grease will help lift dirt off the parts prior to reassembly.
Duncs
AnswerID: 257615
Reply By: Max - Sydney - Friday, Aug 17, 2007 at 17:28
Michael
The best tool for packing grease into a bearing is a small zip top plastic bag. Put the bearing and half a handful of wheel bearing grease in, then squish and squash it around till all the grease has gone into the bearing. Put more in till no more will go into the bearing, but don't stick and "spare' into the hub - it does not good and can build up pressures.
Certainly replace the seals (as stated above), and make sure you tap off the outers and replace them too when you replace the bearings. Before you put any on, make sure the axle is nice and smooth - rub with a very fine wet and dry paper to get rid of any "dags" as they can cause the seal to fail.
If nothing goes wrong, the distance / time between repacks in the owner's manual should be ok, but the inspections in between are essential to pick up problems - as you just found out.
Hope that helps
Max
AnswerID: 257700
Reply By: Michael46 - Friday, Aug 17, 2007 at 21:31
Thanks to everyone that replied. From the feedback I think I will stick to repacking manually.
AnswerID: 257759
