Tyre size for Gu Patrol
Submitted: Saturday, Aug 18, 2007 at 22:23
ThreadID: 48830 Views:3589 Replies:5 FollowUps:2
Just purchased a 4.2 GU with 17 inch rims and tyre size of 265x 65x17 and and wondered if I can fit 15 inch or 16 rims.
Reply By: Member - desray (WA) - Saturday, Aug 18, 2007 at 22:32
15" rims wont fit over the brakes. 16" rims fit ok with 285X75X16 tyres (33") diam.
AnswerID: 257869
Reply By: Skippy In The GU - Saturday, Aug 18, 2007 at 23:47
I know a few people that do run 15's on there GU series 4, same brakes as series 3 I think
AnswerID: 257876
Reply By: Fleggy - Sunday, Aug 19, 2007 at 09:52
I can vouch for 16" rims running 305x70xR16's for my 04 GU. There is a 'tiny' bit of scrub at full lock when reversing out of my driveway, otherwise all is fine :)
AnswerID: 257895
Follow Up By: Doggy Tease - Sunday, Aug 19, 2007 at 20:13
Gday Fleggy, yours is a series 111 mate,they came out with 16's as standard...:)
Back on topic tho. We have a 06 GUIV and run 16inch rims no probleem at all. Tires are 265/75r16's,
meow.
rick.
FollowupID: 519252
Follow Up By: Fleggy - Sunday, Aug 19, 2007 at 22:37
Heh, yeah your right rick and thanks for pointhing that out to me - it was early this morning when I replied to that and had just been woken up by a call out from work. Should have twigged when reading it that I had a different model!
FollowupID: 519276
Reply By: Robin Miller - Monday, Aug 20, 2007 at 15:01
Hi Roger S
As from posts there are a few differences in brake caliper sizes etc over the years so check any rims first.
Generally speaking the ROH Trak 11 rims are reccomended as they have better offset and in any given wheel size will fit more cars.
I use 16 in trak 11's and mostly run large diameter but skinny 255/85/16 for my car, a Patrol 4800 which has the biggest brake size.
15 inch will fit some 4.2's - but check
Robin Miller
AnswerID: 258082
Reply By: Member - Luke (SA) - Tuesday, Aug 21, 2007 at 17:05
When I bought my GU it had 15" sunraysias on it, after a while I replaced them with a set of alloys (don't know the name but I think they were ROH).
After a while I had a vibration and was looking under the front and noticed the brake callipers were rubbing away at the stick on weights on the inside of the rim. Just something to look out for also
Now have 16"s
Cheers Luke
AnswerID: 258302
