What lubricant do you use
Submitted: Sunday, Aug 19, 2007 at 21:13
Member - Crazy Dog (QLD)
Ok troops - I have just bought me a really really really really really really really nice 1996 80 series cruiser and would like to take your advice and give it a new timing belt , filters and oil.
The question is with 290ks on the clock and according to a mechanic friend the motor sounds tight - whatever that means, what oil should I be using in her?
I will NOT be using cheap stuff so your valuable input is requested.
I live in
Cairns - tropical and intend to venture west across the top and maybe even up the Cape..
Grrr!!!
Reply By: Markymark - Sunday, Aug 19, 2007 at 21:23
My '98 Petrol Prado uses Penrite HPR 10 semi-synthetic, $40 for 5 Litres. My wifes VT Commodore has Catrol GTX 2, $17 for 5 litres.
Mine has 170,000km, hers 160,000km. Last oil change the Castrol was black as black while Penrite still had a golden touch to it. Both cars have been
well serviced, maybe it's Toyota engines being cleaner than Holden ones, maybe it's the oil? Who knows, but I'll keep using Penrite in the Prado and down the track when finances improve I'd like to use their fully synthetic one.
Mark.
257991
Follow Up By: AndrewX - Monday, Aug 20, 2007 at 09:31
It means the Castrol is cleaning the engine and the synthetic Penrite isn't. Oil in a diesel is black before you get around the block by the way.
519299
Follow Up By: Axel [ the real one ] - Monday, Aug 20, 2007 at 14:54
Andrew X , would you care to bet on your statement "oil in a diesel is black before you get around the block" ,, 372,000 klm ,oil+filter change every 5 thou and funny that my oil stays a light golden colour for the duration.
519347
Follow Up By: Markymark - Monday, Aug 20, 2007 at 22:47
Both my vehicles are petrol!
Mark.
519474
Reply By: Member - Jiarna (NT) - Sunday, Aug 19, 2007 at 21:29
I use Synforce Cruiser Oil in
mine, and very happy with it. Now up to 396,000 km and still going strong.
257993
Reply By: Member - Crazy Dog (QLD) - Sunday, Aug 19, 2007 at 21:30
Whoops! silly me - it is a normally aspirated diesel 4.2 I believe...
Grrr!!!
257994
Follow Up By: TD100 - Sunday, Aug 19, 2007 at 21:39
i was going to ask that,anyway i swear by peak global performance diesel 15w40 used it in various diesels over 15 years and wouldnt use anything else,good start up flow and hot oil pressure,pull it out after 5000k and its still has a golden colouur to it.cheers Paul
519270
Follow Up By: Andrew from Vivid Adventures - Sunday, Aug 19, 2007 at 22:06
AMSOil right?
519271
Reply By: Geoff (Newcastle, NSW) - Sunday, Aug 19, 2007 at 22:59
Hi Crazy Mutt,
In the last three Landcruiser diesels I've used Rimula X, not the dearest nor the cheapest but they've all done better than 500,000 k's on the stuff.
The latest Troopy RV factory TD is still on Rimula X. After 50,000 k's is doing fine, I know it's barely run in but the oil seems to work.
Geoff
| Geoff,
258000
Follow Up By: Bob Y. - Qld - Monday, Aug 20, 2007 at 11:23
Crazy,
I'll put in a vote for Shell Rimula X 15W/40, as
well. Been using it for many years, with no dramas.
Any diesel oil would do, as long as
services are regular.
Hooroo...
519314
Follow Up By: Stu050 - Monday, Aug 20, 2007 at 11:34
I'll put in another vote for Shell Rimula X 15W40, also been using it for many years, both in diesel and petrol engines.
519320
Reply By: Steve from Top End Explorer Tours - Sunday, Aug 19, 2007 at 23:22
I have owned 7 1HZ cruisers and only put Penrite HPR diesel oil in them, I also use Sakura filters.
I change my oil, oil filter and fuel filter every 6000/ 6500 km, I check air filter, grease and other fluids as
These filters and oil have never let me down, I have 1 engine that has done 300000 km 1 that has done 170000 1 that has done 270000 and my new one about to do 100000, they purrs like a kittens.
Hope this helps.
Steve.
258004
Reply By: Member - Troopytrek - Monday, Aug 20, 2007 at 05:42
G/day Crazy dog, I use Penrite HPR 30.My old man uses HPR Diesel for his1HZ . Have been using it for years and absolutely love it. Had a friend service my troopy once and he used conaco and it used more oil than petrol, I changed back to penrite and have never had the problem again.Cheere Troopytrek
258012
Reply By: Willem - Monday, Aug 20, 2007 at 08:21
Doggy,
KY?
hahahahaha
You can use any oil you like 'cos by 290,000km the enigine is
well run iun. Probably use a thinner oil for the tropics. Still, there is lots of good advice on here re oils. I use whatever my garageman has in stock at the time. At the moment it is
Mobil Delvac 15/40
258020
Follow Up By: Axel [ the real one ] - Monday, Aug 20, 2007 at 09:46
Why would anyone use a thinner oil in the tropics ?? a slightly thicker oil makes more sense as after shutdown the thicker viscosity oil will stick better, ready to give protection on startup than a thin oil running straight back into the sump ,, 372.000 klm Valvoline super diesel.
519302
Reply By: Zodarp - Monday, Aug 20, 2007 at 08:37
Change mechanic not oil.
Regards Zodarp
258025
Reply By: Alan H (Narangba QLD) - Monday, Aug 20, 2007 at 16:36
Crazy Dog
I use Synforce oil in my 80 series and have found it to be okay.
I also put their All Terrain 80 in the gearbox where it is wonderful for taking the notchy shift out of the box and has improved the gear change.
258107
