Its wet out in the Victorian forrests
Submitted: Monday, Aug 20, 2007 at 08:26
ThreadID: 48864 Views:3376 Replies:4 FollowUps:2
After a couple of years of being able to drive most tracks it looks like the set in mush is back, or at least thats what we concluded during one of a number of short all wheel slides over the weekend.
On this mission we were on a neighouring property re-opening a short 1km dead end track into a forrested gully that had not been driven for a while.
Knew in advance that this track was likely to be right on our driveable limit so we took two cars 300 ft of ropes, all the recovery gear and son was riding my trail bike ahead giving us
text message advice. Times do change don't they !
Left one car at top of track as backup, even though average slope was only about 20 degrees.
Muddies were set to low twenties and we edged slowly down, winding in and out between small gums.
But about 1/2 way down got the message that track was impassable due to large downed trees.
Tried to stop with mixed success as operator error caused a couple of wheel lockups and short slides as I grabbed the handbrake for assistance temporarily forgetting that my current Patrol didn't have a tailshaft handbrake.
Just ahead was an off camber downhill bend around a tree and the track surface was also thickly laid with wet leaf matter.
The only thing I could really do was to inch forward so as not to build up any momentum whilst steering around the tree and hoping the tail end would hold.
This took some minutes to cover a whole 10 meters and definitely caused some sweaty palms.
Next we successfully slid to a stop just above a huge curved fallen tree section that had come down such that its end speared into the very middle of the track forming a sort of arched bridge some 2m high.
Spent about a hour clearing all the minor stuff away using most of our chainsaw fuel to get a clear shot at the suspended 3 or 4 tonnes of tree which looked from a distance like a bridge over the track.
This was potentially a risky situation as the car was in the way if the tree moved in the wrong direction and we could not winch the tree away even if we had had the traction to hold on the hill.
My brothers solution to this problem was to cut a long lever and put it under the tree where in had speared into the track, and with 3 of us on the lever we got it to fall over off the side of track.
It worked and twenty minutes later we made it to gully bottom and contemplated the return drive back up over some lovely hot coffees courtesy of our new and surprisingly effective Stanley thermos flask.
The bike headed off first, but soon got into trouble and just ran out of traction.
Its a CRF-2320 is well suited to this task, with a healthy amount of low down torque - sort of the diesel of trail bikes. However it tried and couldn't get back up via normal means and had to backtrack and go sideways a few times and with some help
it disappeared up the hill.
Wasn't looking good for the car so we had to make our best choices and count on getting it right first go else the track would be too cut up.
We elected to leave the rear difflock off as they often break traction on turns like this. Set front lock on, and set tyres to 10-12psi and selected usual 2nd low and went off slowly but not real slow trying to keep engine at 1000rpm.
Essentially we choose to rely on traction with little momentum.
While the Patrols big 4800cc petrol engine has plenty of torque it has little engine inertia so you have to be right on and off the gas quickly as required.
As we went up the revs would dip down below 500rpm and occasionally a wheel would spin a little, but slowly we crawled up in a very memorable climb all the time right on the edge of breaking traction but just hanging in there. Passed the bike
stalled after about 300 meters but knew if we stopped we'd stay so we keep on plugging away till we got right to the top much relieved.
Just a pleasant little trip.
Robin Miller
Reply By: Des Lexic - Monday, Aug 20, 2007 at 09:31
Sounds like a fun drive and glad the thermos is working ok LOL.
If you've got slippery tracks then you have had rain. Thats a real bonus. It would be great if you could write one of your expertly written technical letters to the rain gods and get him to make a few deposits over here. Still dry as buggery.
AnswerID: 258031
Reply By: Mr Pointyhead - Monday, Aug 20, 2007 at 11:26
nice bit of driving to get out. It is amazing what can be achieved with good throttle control !
AnswerID: 258055
Reply By: Gerhardp1 - Monday, Aug 20, 2007 at 11:31
Sounds like the best fun to be had with clothes on.....
There must still be some water run-off, because according to the info on the Age weather page, the dam levels are still rising and we haven't had any real rain for a little while.
AnswerID: 258058
Follow Up By: Robin Miller - Monday, Aug 20, 2007 at 11:54
Local paper - Alexandra Standard - reported that on friday the only remaining Vic country area was declared in a drought making state now 100% declared and that local dam (Eildon) was at 20% capacity.
Still nearby forrest was quite wet and got more saturday , so I guess its a very mixed bag.
Robin Miller
FollowupID: 519326
Reply By: F4Phantom - Monday, Aug 20, 2007 at 13:24
We went to toolangi with 6 cars 3 weeks ago inc the new dual cab 4.0L hilux, a couple of GQ's one with 35 claws, prado and my pajero and a lite ace 4x4 with BF AT's. We were about to turn home at 11:00pm on the friday night to have a normal weekend. We decided to do 'one last track' (the lite ace left at this point after filling with water in a hole) it was wet and slippery and there does come a time, at 1:30am at 0 degrees in rain when the lux is in a bog hole with the tyre off the rim that you do wonder what you were thinking and why the track looked so attractive. Eventually we got to the end of the track after hours of effort and it had washed away in a gully with a thin strip left for motorbikes only. We turned around with great effort (the guy who took his dads spanking new lux [told dad it was just to move a couch] was not real happy about giving it first scratches!) and then we had to fight all the way back to the start of the track, but up hill this time. The GQ got a big bang in the side, the GQ with claws hammered a quarter panel in to make it look much more modern, the prado did a full 180 degree turn with all 4 wheels locked down a slippery slope, as mentioned the lux got a tyre off the rim, the pajero slaughtered its 'exceed' side step rails and we all got very tired too. In the end I got to bed at 10 to 6 am and the trip very much influenced what I got done that Saturday contrary to what we set out to achieve. Great stuff, I recon all up we spend a few k that night on our hobby.
AnswerID: 258071
Follow Up By: Pajman Pete (SA) - Monday, Aug 20, 2007 at 13:34
Ah yes, the dreaded OLT - "one last track"
That nearly always spells out trouble! In the 80's against our advice my boss took the work Yota down OLT behind Lake Eildon. We ended up leaving the vehicle at the bottom of the hill and walking 15 km back to the camp (in the freezing dark) for assistance.
But at least you have good stories to tell afterwards!
Pete
FollowupID: 519337
