Dual zone fridge
Submitted: Monday, Aug 20, 2007 at 19:23
Member - Stephen F (VIC)
Good evening Trendsetters,
I am in the process of buying a new fridge and i would like know if any of you peoples have used the engel dual/zone fridge/freezer.
I am leaning towards a dual zone unit because i will be choofing around for 1-2 years, do you think a freezer section is really req? or what do you guys do for a freezer section in your fridge.
Also does anyone own a Sidewinder unit?
Reply By: Willem - Monday, Aug 20, 2007 at 19:34
I have a Two-zone sitting atop my 32lt Engel.
I run the fridge on freeze at all times and the Two-zone works
However, the Two-zone struggles in the Tropics near the coast where the humidity is high.
258152
Follow Up By: Member - Stephen F (VIC) - Monday, Aug 20, 2007 at 20:28
Thanks Willem,
A mate in
Darwin said they same thing about the 2 Zone bolt on unit, they struggle when the humidity is high.
519442
Reply By: tomjones83 - Tuesday, Aug 21, 2007 at 08:30
g'day mate. i cant comment on the two zone but i have a waeco 110l which works a treat and would seem as though it would run a similar system just side by side.
the sidewinder setup from abr is fantastic and very
well built. i have had no probs with
mine at all and i have a 100 a/h battery in there which derek also supplied.
cheers,
Tom
258230
Reply By: lees fishin - Tuesday, Aug 21, 2007 at 10:13
you mat find the dual/zone struggel in the tropics,because the cooling element is only in the freezing section.leaving the fridge section to cool its self of the freezer.this has an uneven cooling afect on your fridge,(no good if you want a cold beer.id stay away from dual/zone in nort aus.just my 2 cents worth
258236
Reply By: Member - Stephen F (VIC) - Tuesday, Aug 21, 2007 at 15:12
Thanks for your input so far guys the unit which i am interested in are the ones like ABR's fridge the engel 60l or the evakool type with a freezer section built in not a bolt on type setup.
As long as the fish stays frozen and the beer are nice and cold i will be a happy camper.
258293
