so called experts, a joke.
Submitted: Monday, Aug 20, 2007 at 19:50
Member - shane (SA)
all i want is to find out about how to increase the axles legal weight, but can't get a straight answer. called a very very large trailer parts supplier here in
Adelaide today to find out what i need to replace. after telling him what size axle i have (45mm square) he tells me it is rated at 1250kg, i tell him that's not right, the plate states 1600kg max axle weight. he tells me noway and that's not what a 45mm axle is rated at. so now I'm all worried. i ring al-ko in
Melbourne who supplied the axle and brake setup, they are adamant that the 45mm axle is rated at 1600kg. al-ko state that a 50mm axle is rated at 2000kg with 12" electric brakes but the trailer company state it is only rated at 1700kg with 12" elec/brakes. where to now? its got me stuffed.
Reply By: Kev M (QLD Bound) - Monday, Aug 20, 2007 at 19:55
Shane,
Give John a call at Specialised Vehicles he is very knowledgable in regards to this, even though he does vehicle mods.
John Burke Contact details
I'm going to get John to do my conversion when I finally get a 100 Series
Cheers Kev
| Russell Coight:
258159
Reply By: Member - Peter R (QLD) - Monday, Aug 20, 2007 at 20:04
I would go straight to the caravan manufacturer to ascertain what are the correct figures for your size van.
A google search may turn this up too.
Am going through having the axle on my Jayco Poptop increased at the moment, and the first thing I had to do was get van weighed , off the ball.
Am getting the axle changed from 1450 approx to 1700 and the only modification needed is the
wheels which need to be changed from 5 stud to 5 stud.
Had I gone for a 2t axle major changes to
suspension, springs etc was necessary and cost very high.
Pedro
258164
Follow Up By: Member - shane (SA) - Monday, Aug 20, 2007 at 20:10
what size axle is the 1450kg? and what is the plate rate?
519439
Reply By: Member - Peter R (QLD) - Monday, Aug 20, 2007 at 21:02
Sorry, don't know the dimensions of axle , as I was only interested in the plate which shows load cap is 1450kg.
Pedro
258176
Reply By: Andrew from Vivid Adventures - Monday, Aug 20, 2007 at 21:34
You just need a compliant authorised ADR trailer manufacturer to review the situation and write the correct numbers on (within reason).
The axle you have may be from a different supplier. It may be different in design somehow...
If you're down South, I may be able to refer you to someone who can help.
258181
Reply By: Member - shane (SA) - Monday, Aug 20, 2007 at 21:42
thank for replies, that would be great if you could.
258183
Reply By: Richard Kovac - Monday, Aug 20, 2007 at 21:46
Hi Shane
Try this site
axle
258185
Follow Up By: Member - shane (SA) - Monday, Aug 20, 2007 at 21:55
have already talked to alko. thanks.
519464
Reply By: GerryP - Monday, Aug 20, 2007 at 22:07
Don't know the relevant ratings, but most axles are solid whereas some are tubing, which in turn can vary in wall thickness. Jeff at RV Trailers in
Adelaide should be able to help, give him a ring.
Gerry
258187
Reply By: Member No 1- Tuesday, Aug 21, 2007 at 10:48
i would believe ALKO
its their axle....they make the things dont they
maybe the guy who says "noway" hasnt heard of ALKO?
258248
Follow Up By: nowimnumberone - Tuesday, Aug 21, 2007 at 19:53
or maybe he is an alko
519624
Follow Up By: Member No 1- Tuesday, Aug 21, 2007 at 20:25
Hey!
your not refering to me eh?
519632
