Magellan crossoverGPS / Garmin
Submitted: Tuesday, Aug 21, 2007 at 19:43
ThreadID: 48921 Views:2437 Replies:4 FollowUps:1
Gidday all
I have a Magellan Meredian Gold with Discover Aus Streets and tracks and have found it to be suprisingly well detailed off road away from towns etc....I now wish to purchase a GPS for the boat...have been looking at the Garmin preloaded with marine and land maps and comparing to the Magellan crossover for which you purchase land or marine maps extra on SD cards
I have heard (may be unfair critisicm) that Garmin land maps arent that flash out of the built up area )....???..if this is so maybe their marine maps are the same standard / detail?
If Magellan mapsend bluenav are as good as I have experienced as their land maps then maybe that is the way to go using the crossover which can serve as dual purpose...bush and beach !
Comments from other users would be greatly appreciated
thanks
VKS 1341
Reply By: Member - Doug T (Qld) - Tuesday, Aug 21, 2007 at 20:43
I noticed on my Garmin when heading across the Hay Plains that the man made canals on each side of the road are on the screen ,when travelling between Ingham & Trebonne i noticed the Cane train lines on the screen,how much better do you want.
But it seems your mind is made up to go Magellan and that's fine, they are a good GPS , There is only two brands to consider, anything else is a waste of money, but just in case you might like to have a geek i added this link.
Garmin GPS Map 276C
AnswerID: 258363
Reply By: Member - bungarra (WA) - Tuesday, Aug 21, 2007 at 20:50
Thanks Doug
No my mind is definately not made up...I only have first hand magellan experience...your comments on the Garmin are noted..will check out the link now..thanks
bungarra
VKS 1341
AnswerID: 258365
Follow Up By: Member - Doug T (Qld) - Tuesday, Aug 21, 2007 at 21:02
Your a bit like with Garmins, I only have know how about the Garmins , I don't think I have the need for anything else
Doug
FollowupID: 519651
Reply By: Member - Doug T (Qld) - Tuesday, Aug 21, 2007 at 20:59
I would suggest you also have a look at these Marine Chart units ,
Marine Chart GPS
Also if you only use a small section of Australia to fish as in a section of WA then you won't need a part of NSW or Qld so in this link you will see what sections are available for a Garmin,
Blue Chart
AnswerID: 258373
Reply By: Member - bungarra (WA) - Tuesday, Aug 21, 2007 at 21:10
once again thanks Doug...I am enjoying reading your links.....yes I am a Magellan man but getting closer to being a Garmin owner...post by post
VKS 1341
AnswerID: 258375
