Putting my GQ on gas and best way
Submitted: Wednesday, Aug 22, 2007 at 11:48
ThreadID: 48932 Views:3387 Replies:5 FollowUps:7
Hey guys, got a 88 GQ 4.2 Petrol and was looking to put it on gas. What are the best options these days in terms of size of tank, where to place it, and which kits to buy. My cousin did his Landy and reckons he could do mine too. Can anyone give me ideas on where to start please...
Reply By: Voxson - Wednesday, Aug 22, 2007 at 13:37
110litre tank under where the main tank goes was my preference when i had a petrol 4x4 GQ.
AnswerID: 258438
Follow Up By: Kylie in the exy - Wednesday, Aug 22, 2007 at 13:44
Thanks Voxson. How did you manage the petrol tank then? A smaller one placed somwhere else?
How did the car run on gas? Was it tuned for petrol or gas? What fuel did you run it on when off road? Was it worth having gas as an option?
FollowupID: 519749
Follow Up By: Smudger - Wednesday, Aug 22, 2007 at 18:17
My son was talked into a 110litre tan on his shorty Patrol. He lost a fair whack off his departure angle. A new set of springs and shockers, and $1,000 later he's sorta back where he was clearance-wise. I think he also has a 90 litre petrol tank.
Meantime, I have an 80 litre tank under my Disco, and a couple of petrol tanks (110 litres).
Obviously, he doesn't have to fill up the LPG as often as me, but I don't mind, I kinda like filling up from empty and only paying $35 for the privelege.
You probably don't need a huge tank, just means having to fill a bit more often. I went to Adelaide not long back, I left with a full tank, filled twice on the track and arrived with about quarter of a tank. Cost ..$120 / 1300km
FollowupID: 519794
Reply By: stefan P (Penrith NSW) - Wednesday, Aug 22, 2007 at 16:08
G'day Kylie,
I had a 90lt gas tank where the main fuel tank is now, then I had a 100lt aftermarket fuel tank in the middle of the car, You need to have a decent fuel capacity as when off road my gas would only last around 200kms, so I needed the fuel as back up. It seemed I was forever trying to get the tuning just right. It was always better on petrol or better on gas, never perfect on both. But go for it as it made the car quite cheap to run around town in.
Cheers Stefan
AnswerID: 258449
Reply By: theo5530 - Wednesday, Aug 22, 2007 at 17:52
There have been alot of recent changes to the gas industry in recent 12 months . The gas that we use here in Aust is now allowed to be suppllied from S/E asia this means it is not refined to the standard that it used to be therefore you need to make sure of a few things..1. demand copper lines this will be legislated in the coming year but at the moment they can and will fit the rubber ones. This causes a LEACHING from the rubber resulting in a brown leakage from your vehical ( I only know all this from a 6 mth court battle with a gas intalling company) 2. make sure you get a gas peterol start system this makes it easyier to start .... all I can say is RESEARCH REASEARCH RESEARCH they are becoming a worse industry with the gov rebates on offer they will take your money and palm you off after that. after 6MThs our car is still not running properly my advice save your dough and put it towards fuel...
AnswerID: 258465
Follow Up By: Brew34.5(SA) - Wednesday, Aug 22, 2007 at 19:09
I would disagree with the petrol/gas start as you lose the flexibility you have.eg...... if you have petrol problems you can still run gas and vice versa. I thought only EFI conversions had this option???
FollowupID: 519803
Reply By: Brew34.5(SA) - Wednesday, Aug 22, 2007 at 19:21
I have just recently sold my 89 GQ which was on gas. I can offer you some pretty good advice.
1. Being an 88 model it will have a points distributor. Do yourself a favour and install an electronic ignition conversion.(best $$ you will spend)
2. Put 8mm minimum(9mm is what i had) leads.
3. Change the spark plugs.
4. Put an exended rotor button in the distributor.
I loved my GQ on gas and never had any of the problems people talk about with the head. (just make sure your cooling system is top notch) You will use about 23lt/100km.
I had a 115lt usable tank where the original tank was located and a 75lt ulp belly tank which ran down the drivers side under the vehicle.
I had 4 inch springs on the rear and 2 inch springs on the front and never had clearance issues.
Mine was an Impco system and after the installation of the electronic ignition has no tuning issues at all after 50,000kms.
Do the the conversion. With the Govt rebate you will be well in front in less than a year.
AnswerID: 258482
Follow Up By: Kylie in the exy - Friday, Aug 24, 2007 at 20:03
Thanks for the tips guys - I appreciate the advice.
I did get the electronic dizzy installed a few months ago - is that what you are referring to?
I have also had a new radiator fitted last summer. I have fitted 4" springs and suspension for towing the camper trailer. I run 33's on it too.
Have I missed anything else that will make it run better? It has a snorkel and dual battery system. Oh a fridge slide and a draw. Great car but how can I get the fuel consumption better?? I get around 400km to a tank (95lt).
Hey Brew - which type of system did you have?
Kylie
FollowupID: 520189
Follow Up By: Brew34.5(SA) - Friday, Aug 24, 2007 at 21:32
Impco Gas system. Ignitor Ignition.
Thay are a thirsty beast mate so good luck improving the economy. Thats why most people end up doing the LPG conversion. I'm in a Diesel now and its about 25-30% more expensive to drive than the gas patrol.
FollowupID: 520226
Follow Up By: Kylie in the exy - Monday, Aug 27, 2007 at 09:40
Ignitor Ignition - Forgive me Brew but that is different from the elec dizzy correct? Where do I get one from?
I did consider off loading the GQ Petrol and going for the diesel option. Worse off you say? why is it more expensive the cost of diesel or other factors?
My GQ is my second car, I use the Xtrail for day to day stuff. It was brought primarly for 4wdriving. Hence why I never brought one on gas to start with. But now, I want to do the touring stuff. Xmas 08 I want to do NT for a few weeks. I was thinking of getting gas for that trip but alot of people have mentioned that gas is not available in most places.
What are your thoughts please.
Is there anything else you can suggest to do to the truck?
I have done the leads and the plugs as mentioned.
Thanks again for your time.
Kylie
FollowupID: 520491
Reply By: outback epicurean - Wednesday, Aug 22, 2007 at 21:53
Can I back up the comments about the need to improve the electricals when converting to gas on these older GQ. Had an 89 on gas and constant problems getting it to run properly on gas. After spending a lot trying to get it tuned properly told to fit new bigger plug leads etc but by then was sick of it and bought a diesel patrol. I think this is an option to consider as fuel consumption with gas is very low and no range if you are travelling outback. Also, very few places have gas. If you are all around settled areas probably OK. Diesel is avaiable everywhere.
have fun
AnswerID: 258517
Follow Up By: Kylie in the exy - Monday, Aug 27, 2007 at 09:52
Thanks for the tips. I have already spent the $$ on this one though. Looking at doing the NT next yr - any tips??
I think I will bite the bullet and go with the petrol option ...
FollowupID: 520492
