Aero vs square roof bars
Submitted: Thursday, Aug 23, 2007 at 13:13
ThreadID: 48962 Views:2479 Replies:4 FollowUps:0
Is there much of a difference in wind noise between the aero and square-shaped bars. I assume the aero bars were designed for a reason, and not just because they look better?
Also, square bars make it easier to mount things off - lights, aerials etc.
Reply By: Ingtar - Thursday, Aug 23, 2007 at 13:20
Isn't that why most things are made newer? Because they look better? Certainly helps sell more.
I have used some very old bars/roof racks that have made no more noise than some of the newer ones. And the newer ones were in a newer car with better soundproofing.
Personally I would be looking for what suits what I want to use it for in particular strengthwise and if it would suit you better for mounting things then factor that in.
AnswerID: 258595
Reply By: MEMBER - Darian (SA) - Thursday, Aug 23, 2007 at 13:30
Yep - the aerodynamic, lower profile bars are quieter than square jobs - have both types on cars in our family at present.
AnswerID: 258597
Reply By: Chris & Debbie - Thursday, Aug 23, 2007 at 13:54
I just went through this exercise and found that the Aero bars are quieter, have the same load rating and have nearly as many accessory mounting adapters, so I could see no advantage of having the square shape unless you needed flatter load carrying surface for some reason.
Chris
AnswerID: 258601
Reply By: ben_gv3 - Thursday, Aug 23, 2007 at 15:00
I was thinking the square bars as they are cheaper and I can fabricate mounting adaptors a lot easier. I know you can buy adaptors for aero bars but aren't they all proprietary?
I'm not after load carrying capacity as I only really want them to mount things off - lights, aerials, gps receiver etc.
The aerial mounted on the roof rack is much better then the bull bar/fender locations IMO
AnswerID: 258610
