A non-controversial fridge/electric question!
Submitted: Saturday, Aug 25, 2007 at 05:03
ThreadID: 49005 Views:2944 Replies:3 FollowUps:2
Guys,
I really don't want to start a problem here, but have a question... I recently acquired a 40L National Luna (I am in Africa mind, so please don't go mental cause it is not Waeco/Engel!) I am having a real problem getting decent fuses. Is there a difference betwwen say a vehicular fuse that runs on 12v DC and the same amperage fuse (or circuit breaker) that is made for household voltage. May seem stupid, but there you go! Oh, and before you ask the wiring is really heavy and there are no cigar type connectors in sight . Oh and if anyone is interested the fridge seems bl**dy well made.
Gil
Reply By: Mike Harding - Saturday, Aug 25, 2007 at 08:18
The current rating of a fuse is the same (for practical purposes) irrespective of the voltage of the circuit it is operating in. However the voltage rating is not - so it is OK to use a 240V fuse in a 12V circuit but a 12V fuse must NEVER be used in a 240V circuit.
Mike Harding
PS. It's not a stupid question it's actually a very good one.
AnswerID: 258832
Follow Up By: Member No 1- Saturday, Aug 25, 2007 at 11:47
a lot of folks wouldnt know that, and put their life or someones elses at risk
12v cable/wire/fuses/switches (anything made for low voltages) doesnt require as good as insulation as 240v stuff requires
FollowupID: 520269
Reply By: Peter 2 - Saturday, Aug 25, 2007 at 10:53
It is actually a good idea to use a household cartridge type fuse for high or constant drain 12v accessories as they usually have a large contact area on each end of the fuse and large contact area where they pug into the holder meaning that there is little chance of voltage drop.
Codan and Barrett both supply a large 240v cartridge type fuse and holder with their HF radios for just that reason.
I also use one for the frig and the compressor.
AnswerID: 258839
Follow Up By: Crackles - Saturday, Aug 25, 2007 at 15:13
The exception to this is that some household 240Volt fuse holders & wire are not made for the vibration or waterproofing required in a car & wont last very long.
Cheers Craig..............
FollowupID: 520296
Reply By: gilghana - Saturday, Aug 25, 2007 at 15:55
Many thanks for the replies - big problem solved! Will now get some big household type fuses as teeny blade fuses were my problem: dozens of 'em but no decent holders. The National Luna seems be be a pretty well made piece of kit. Cheers guys,
Gil
AnswerID: 258860
