4.5 gu Gas conversion
Submitted: Saturday, Aug 25, 2007 at 21:15
Ferret
Greetings all, can anyone tell me the biggest gas
tank you can get under a 4.5 GU, and the biggest subtank. Also, has anyone done one of those new Gas injection type systems and what do ya reckon on them .
Many thanks
Scott
Reply By: zumzum - Sunday, Aug 26, 2007 at 08:43
I have a 110 L. gas
tank fitted on my landcuiser. I can fill only about 92-95 Lt. of gas on it...
Luca
258925
Reply By: Trevor M (SA) - Sunday, Aug 26, 2007 at 13:27
I have a 110Lt (95 - 100Lt useable) gas
tank and have just replaced the 40 Lt petrol sub
tank with an 80 Lt long range sub
tank.
The only issue with gas is that it is not available when you head into more remote areas. Crossed the Simpson a few weeks back and took another 70Ltrs in Jerry's. Ran on Petrol using the gas as reserve only as unable to replenish.
258941
Follow Up By: Ferret - Sunday, Aug 26, 2007 at 21:50
Cheers, already got a GQ on duel fuel but looking to upgrade and was wondering if you can get bigger tanks under the GU. Where did you get your sub
tank from and can I ask the price>
Many thanks
520459
Reply By: Trevor M (SA) - Sunday, Aug 26, 2007 at 21:55
My sub
tank is from 4WD Systems. It was somewhere between $650 and $700 from memory. I fitted it myself but next time would spend the $350 quoted for fitting in a flash.
Trev
258998
Follow Up By: Ferret - Sunday, Aug 26, 2007 at 22:22
Many thanks, what sort of mileage do you get out of yours?
520466
Follow Up By: Trevor M (SA) - Sunday, Aug 26, 2007 at 22:26
Blo@dy Shocking!
There is only marginal diff between the gas and petrol. The 80 Lt petrol only gets 300 - 350 k's.
The 100 lt gas is probably about 350 k's
520467
Follow Up By: Ferret - Sunday, Aug 26, 2007 at 22:29
Yeah, about the same as my GQ, pretty crap. Do you find it has enough oomph for towing etc as my GQ (338,000) can be left wanting sometimes.
Ta
520468
Follow Up By: Trevor M (SA) - Tuesday, Aug 28, 2007 at 08:37
Don't do a lot of towing sorry so can't say. It is a bit of a "lumbering giant" and no sports car but not much it doesn't seem to handle if given time to do it.
There is little noticeable difference in performance between gas and petrol except that I have a flat spot when on gas (more noticeable around town than when on the road).
Trev
520625
Reply By: flappa - Monday, Aug 27, 2007 at 09:14
I have a 110l gas
tank and a 75l petrol
tank on my GU
I believe you can get a bigger fuel
tank , but I didn't bother.
When I was researching the gas conversion, I was told by a couple of knowledgable people , that the new gas injection systems dont provide any great benefit to the 4.5 GU. The older system works plenty
well enough.
Completely different story for the 4.8, which I understand, HAS to have the new injection system fitted.
Had my gas conversion for just over 12 months now. Haven't had a problem yet.
I get approx 350 k's out of gas , and about the same out of petrol.
259025
Reply By: Ferret - Monday, Aug 27, 2007 at 16:17
Many thanks everyone for your replies
259070
