Fuel economy 2nd tank
Submitted: Monday, Aug 27, 2007 at 00:51
ThreadID: 49053 Views:2469 Replies:5 FollowUps:4
Just got back from a trip to the Karroun Hill Nature reserve and baladjie (SP??) rock the first part of the trip was major, and secondary bitumen, well formed gravel road and some track driving. I swapped tanks from the main when the light was on fairly steadily at 600km.
For the sub tank the driving was good dirt roads and secondary as well as highway bitumen and it ran out at 320km.
Filled up at the same Servo (big gull servo between Northam and sawyers vally) same pump and put in
50l into the sub = 15.6lph
80 l into the main = 13.3l per hundred
and overall
130l for 920k for 14lph
Why the diference??
I didnt see much in the way I drove to make such a difference if anything the slow 2nd and 3rd gear driving on the main should have used more
Reply By: Rock Ape - Monday, Aug 27, 2007 at 06:52
Davoe,
did you fill the aux tank at gull before the trip, your thread indicates you did. If you didn't there could be a couple of reasons,
old fuel or bad fuel.
After that I can't give a reason except for head winds, altitude, rain, temperature or speed as you say the there wasn't much difference in the roads.
I have had the same thing happen recently on a 3500k trip.
Was running between high 11s to high 13lts/h, then one load of fuel went in the mid 15s for no apparent reason. Not much changed ie: road conditions or speed except some of the other readings came from slow 4wd through the scrub and did not change the fuel much.
You didn't say if you have checked your fuel usage after the trip.
Have a safe one
The Ape
AnswerID: 259009
Follow Up By: Member - Davoe (Nullagine) - Monday, Aug 27, 2007 at 10:06
Was very windy yesterday although I didnt feel like I was pushing her into a head wind. Tanks were fairly empty before I filled (took about 120l) soold or bad fuel shouldnt be a problem.
I have only done about 30k since refilling so I am unsure of its current usage
FollowupID: 520493
Reply By: Bilbo - Monday, Aug 27, 2007 at 10:19
This happened to me twice on my latest 4 month trip and I have only one explanation that I can come up with - we've been done.
I know it sounds drastic but it does happen. I couldn't explain it any other way when it happened to me. By way of example read on:
On our last trip away, I was in Kunnunarra using the car wash at the Shell and had to get some dollar coins for the slot. So I'm stood in queue waiting - and a VERY big queue it was. There musta been about 30 people waiting to pay for fuel.
At the head of the queue there was a guy refusing to pay for his diesel as he reckons his tank only held 85 litres and the pump siad he took 100 litres. I can't remember what vehicle it was - mighta been a Prado or something like that - but he was adamant and ropeable that he was being overcharged. When this happens, all ya can do about it is to pay for the fuel and then write to Shell and ask them to check it out. If you're right, you get the overcharge refunded. If ya drive off without paying then you become guilty of stealing.
The guy at the till was doing a mighty job under a lot of pressure, insisting that he couldn't give the guy a refund and he would have to contact Shell. People in the queue were getting a bit wound up with this customer saying,"He's told ya what to do about it, now MOVE!"
It happens
Bilbo
AnswerID: 259030
Follow Up By: Member - Davoe (Nullagine) - Monday, Aug 27, 2007 at 10:40
same pump same place etc if anything it was the other way
sub tank is meant to hold 55l i ran it out and it took 50l
main should hold 90l and it took 80 with the light being on steady for a while
(yes i had 2 back up jerries) just wanted to get back to that gull
FollowupID: 520494
Follow Up By: Bilbo - Monday, Aug 27, 2007 at 11:34
I've had it the other way as well. Inexplicably good fuel figures for no apparent reason!
Bilbo
FollowupID: 520497
Reply By: Member - Matt M (ACT) - Monday, Aug 27, 2007 at 10:46
Davoe,
Not sure if the system in the diesel is different from the petrol, but my 80 runs the tranfer pump for a few seconds after startup. Over time this has the effect of giving better 'economy' from the main tank and poorer for the sub-tank. Gets more noticeable with lots of stopping and starting which you probably weren't doing anyhow.
Matt.
AnswerID: 259033
Follow Up By: Member - Davoe (Nullagine) - Monday, Aug 27, 2007 at 10:54
yep its completly differnt with 2 solonoids controlling draw and return keeping the 2 tanks seperate from each other
FollowupID: 520495
Reply By: Bware (Tweed Valley) - Monday, Aug 27, 2007 at 17:52
I don't know the reason, Davoe, but I noticed the same thing a couple of months ago (80 series diesel) and at first thought it was the station I was filling up at. But over a couple of months I've consistently used an extra litre per 100km on the sub tank. I've eliminated all the variables like where I fill up etc; it's got me baffled.
AnswerID: 259087
Reply By: GRAEME. - Monday, Aug 27, 2007 at 19:39
You don't say what vehicle you have so I'm guessing 80 series deisel. When I fill mine (sub tank) the flap doesn't close off the main tank completly so some of the fuel goes into the main tank.
If I use just the sub tank then fill it it holds about 40lt and the main tank about 80 lts.
AnswerID: 259108
