www.ExplorOz.com
Your browser does not support the site menu
Click Here
to load alternative navigation.
Latest News
Road Conditions
Updated 20/08/2008
Top End
Updated 18/08/2008
Aust. Capital Ttry
WA South Coast
Pilbara
WA Coast
Kimberley
Road Conditions
All News...
Site Updates...
Search by Topic
Live Weather
4WDriving
Accessories
Accommodation
Activities
Boating
Campers & Trailers
Camping
Caravanning
Communications
Cooking
Driving Skills
Electrics
Fishing
Itineraries & Planning
Membership
Motorhomes
Navigation
Permits
PlotSwap
Recovery Gear
Servicing
Survival
Technical
Things To Do
Topics
Tours
Trek Notes
Trips with Kids
Tyres
Vehicle Choices
Visit Australia
Newsletters
Your Name
Email Address
Past Newsletters
Full Index
161
162
163
Current Users
Members
47
Customers
Visitors
44
Anon
1562
Total
1654
List...
Not Logged on
Hand winch Vs Electric winch
Submitted: Monday, Aug 27, 2007 at 10:31
brushmarx
Article Overview - Winches
All travellers should be capable and equipped for winching so in this article we will discuss the various winching methods and equipment on the market.
View Full Article...
Hi all
This is not a question to favour hand over electric or vice versa, not price related, or speed and ease of use, but, why are average electric
winches
rated from 9500 to 12000 lbs but hand
winches
around 2.3 to 3.5 tonnes? (5000 to 7700lbs)
e.g. If a 2.5tonne (5500 lbs) tirfor style winch can pull out a vehicle safely, why do we need 9500 lb electric, or if we need 9500lb electric, why don't tirfor etc make bigger hand
winches
Cheers.
Click Image to Enlarge
Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the present..................Oogway
Member:
My Profile
Advertisement
Suppress Advertisement - Members Only
AnswerID: 259035 Submitted: Monday, Aug 27, 2007 at 11:04
pepper2
replied: There are bigger hand
winches
available Size???? But when you have 3 tons of vehicle badly stuck you need every bit of 10000lb pull sometimes you use a snatch block for 20000lb pull.
Have had my patrol badly stuck where 10000 pul wouldnt move it.
But a hand winch can be very effective in majority cases and pull from any direction,sometimes i carry both...
Reply 1 of 6
AnswerID: 259046 Submitted: Monday, Aug 27, 2007 at 12:39
Wizard1
replied: Hand
winches
, also known as creeper
winches
, like Tirfors, are actually designed for lifting and all standards and ratings apply to their application in the construction industry.
Their rating applies to the device's ability to lift weight vertically say 2.5 tonne, hence what appears to be a much lower rating.
But when you pull something horizantally it all changes due to the physics of pulling rather than lifting. Add a snatch block or two and the weight it can pull goes up again.
You can get bigger ones, much bigger, for recovering trucks which are rated at around 5000 kg, but to recover a 4WD a 2.5 tonne is enough.
Here is a site link that might help.
Industrial Hand Winches
Reply 2 of 6
FollowupID: 520511 Submitted: Monday, Aug 27, 2007 at 13:49
Member - Beatit (QLD) posted:
Also when looking at the hand winch cable it is obviously thicker and one would think it would have greater capacity. But the pull is only as good as the operator and that is why I got my teenage son to do it for me last time - figuring he would be good at that.
Kind regards
On the off-road and ready to go.
Member:
My Profile
My Blog
AnswerID: 259048 Submitted: Monday, Aug 27, 2007 at 12:54
Mikee5 (QLD)
replied: I have an idea it may be because an electric winch only achieves its maximum rating on the first layer of wire. Second layer is less and third layer is less again. Hand winch is constant rating. just my thoughts.
Mike
Member:
My Profile
Reply 3 of 6
FollowupID: 520512 Submitted: Monday, Aug 27, 2007 at 14:38
Wizard1 posted:
So is that to say the further you are away from an anchor point and hence wind out more cable that you have reduced capacity?
AnswerID: 259067 Submitted: Monday, Aug 27, 2007 at 16:00
gilghana
replied: Actually the other way - the less wire on the winch drum the greater the pulling capacity. The pulling Vs lifting scenario is 100% spot on - last weekend I was looking at one of our CAT skidders in the w/shop, betwwen teh winch wire and the hook was a rated 3 ton D shackle (rated for lifting): it was a "bit" deformed but had been regularly subjected to at least 15 tons of pulling!!! Wouldn't have wanted to be near it, but there you go...
Gil
Reply 4 of 6
AnswerID: 259088 Submitted: Monday, Aug 27, 2007 at 17:57
Member - Shane D (QLD)
replied: EFFORT!
That's the short answer,If you have ever used a handwinch, say, in a deep mud situation, you will most certianly feel it through your whole body, YEP, a snatch block will half the effort,but will half the speed and double the amount of pumps.
I never seen any bigger hand winch(NOT saying they dont exist) commercially available,but owning and using H/winch I personally wouldn't want anything that would weigh more, remembering that it will have to be heavier.
Your body can only expell X amount of energy,so gear reduction will result in bigger loads being pulled at a reduced speed.
Shane
Always keep your words soft and sweet, just in case you have to eat them!
Member:
My Profile
Reply 5 of 6
FollowupID: 520590 Submitted: Monday, Aug 27, 2007 at 22:38
Oztravellers posted:
As well as pulling out the 4wd (which I have done when it was bogged to the axles in mud) I have also used the Tirfor for pulling out tree stumps!! Sparky
AnswerID: 259237 Submitted: Tuesday, Aug 28, 2007 at 16:14
brushmarx
replied: Thanks all for your responses.
I guess we need to use Newtons 6th law of motion. A 2.5 tonne vehicle in 600mm of mud requires a horizontal pull of C=At x 4 in 30 degrees celcius, +/- 5% per degree of ground slope.
I used a tirfor in a previous life (army) and although heavy, bulky, and physically difficult use, we saved four Landrovers from sliding sideways down a steep mountain slope by side mounting on the chassis and pivoting off a tree when the only way out was a track washed away in a storm.
Member:
My Profile
Reply 6 of 6
Page Sponsors
Affordable Batteries & Radiators
Derek Bester of Affordable Batteries&Radiators ‘ABR’ is creating a new experience in 4wd accessorising with personal one on one customer service. At ABR we will walk you through your requirements and send you photos, data sheets and personalised quotes.
P.O. BOX 4065 GUMDALE QLD 4154
Phone: (07) 3890 5899 Mobile: 0404 097 627 Fax: (07) 3348 8704
Email:
Send Enquiry
Web:
www.sidewinder.com.au
Member:
Business Profile
Evakool
Australia's largest manufacturer of 12v/24v portable refrigerators and iceboxes. Made in Australia for Australian conditions.
16 ENTERPRISE STREET CALOUNDRA QLD 4551
Phone: (07) 5492 7777 Mobile: 0422 391 890 Fax: (07) 5492 7733
Email:
Send Enquiry
Web:
www.evakool.com
Member:
Business Profile
New/Updated
West Australian Map Book $9.95
Wildflower Country $9.95
Nissan Patrol GU Rear Door Bracket Extension $26.95
SPOT Satellite Messenger $249.00
Navy/White Racer Polo Shirt - TMTE $37.00
Mens Navy/White Polo Shirt - TMTE $31.95
Ladies Navy/White Polo Shirt - TMTE $31.95
Khaki Polo Shirt - TMTE $24.95
Fast Find
Shop Home Page
Discounted Items
Latest/Updated
All Items
Home
About Us
FAQ
Feedback
Site Stats
Membership
Advertising Campaigns
Site Updates
Forum
Blogs
Forum Archive
Trader
Shop
Treks
Places
Directory
Articles
Topics
RSS Feeds
Link to Us
Terms of Use
Corporate Membership
Privacy Policy
Copyright © 1999 - 2008,
I.T. Beyond Pty Ltd.
All rights reserved.
