anyone else had trouble with GU Auto Locking Hubs?
Submitted: Tuesday, Aug 28, 2007 at 16:19
Member - Coyote (QLD)
I was up the Cape in the last few weeks and developed serious creaking noises etc in front right hub. 4WD/or 2WD the hub has become damaged for who know's what reason. I got mobile again by installing a GQ manual locking hub nad leaving it locked in. Then on my
my home the front Left hub started the same. However, any further deterioration has been stoped by manually locking the hub and leaving it locked in. It's still under warranty and is going in to Nissan tomorrow, but I was just wondering if this is a known fault or is Nissan going to say it's my bad driving/the corrugations that have caused it?? any advise appreciated. Thanks.
Reply By: Member - Roachie (SA) - Tuesday, Aug 28, 2007 at 18:22
Sorry, I don't know the answer to your question (about warranty etc)......I have long ago changed my auto hubs over to AVM manual locking hubs and couldn't be happier. I am aware that the really serious blokes (rock-crawlers and comp blokes) say that AVMs aren't strong enough for what THEY do, but they suit MY needs perfectly.
Roachie
259256
Follow Up By: Member - Coyote (QLD) - Wednesday, Aug 29, 2007 at 10:34
Thanks Roachie.. yeah I guess its a good time as ever to switch to manual hubs.
520827
Reply By: Member - DOZER- Tuesday, Aug 28, 2007 at 20:32
Apparently, you can remove the auto bit out of them and turn them into manual hubs....Omit to tell Nissan you went to the cape, they will blame the
water crossings and whatever else they can think of....
259281
Follow Up By: Member - Coyote (QLD) - Wednesday, Aug 29, 2007 at 10:37
Yeah you can, I did this up the cape, a fairly simple task of undoingthe scrwes around th ehub and replacing the maunal hub, making sure of course to put the manual hub in the lock/unlock position depending whatthe auto hub was in when you removed it. Will advise what nissan say this arvo. Byut personally I think that although the Cape is rough, it's nothinga 4WD should not be able to cope with esp a Nissan (if I was in a subarue or Volkswagon etc, I might feel ashamed of myself complaining about it breaking up there, but Niisan preach about their toughness.. I didn't do any 'extreme' 4WD ig with it.. (my bus is a tourer) Cheers
520828
Follow Up By: Member - DOZER- Wednesday, Aug 29, 2007 at 16:47
Im hearing you, but funny things happen when you mention the cape...yes a 4wd should be able to go anywhere, but if you hire one, they draw a line at
cooktown....
Sometimes it is best to omit to mention somethings...for the sake of having a straight claim
520874
Reply By: Muzzgit [WA] - Wednesday, Aug 29, 2007 at 22:52
Yeah, same as Roachie. I ditched the standard Cra bleep an ones and whacked on a set of AVM. TOOOO EASY.
259478
Reply By: mechpete - Wednesday, Aug 29, 2007 at 23:24
Hi Coyote,
Ihave a late GQ with auto locking hubs and not had a hind of trouble in 10 yrs , GRR , Simpson Des , CSR ,Googs and this weekend I leave for another Simpson crossing and they are so handy not have to lock them in manually , pull it into H4 up to 100 kph ,
cheers mechpete.
259490
