Squeaky noise
Submitted: Thursday, Aug 30, 2007 at 15:24
Member - johnathon W (WA)
Hey everyone just want to know I have a squeaky noise in my 2004 v6 gx manual Prado it is there when I am idling and stops when I push the clutch peddle full on or even just a little bit of pressure I need to know what it might be, it does sound like it is coming from underneath, could this have something to do with the bearing to the clutch plate I have a trip coming up in less than two weeks what would be the effect if left unfixed most of all what would be the price to get it fixed. If any one can help that would be great
Reply By: Member - Phil G (SA) - Thursday, Aug 30, 2007 at 16:10
Johnathon,
That noise has been in LandCruisers since the dawn of time. It relates to the fact that the hydraulic clutch has no freeplay. The noise is caused by the release bearing lightly rubbing the diaphragm spring. As a result, the diaphragm spring develops a slight groove and the noise becomes more evident.
The problem will not affect the reliability of your vehicle. Easiest solution is to turn the radio up. If you want the noise to go away, you'll need the replace the whole clutch. Some people spray a bit of grease thru the clutch
fork boot, which is at best a temporary reprieve.
259567
Reply By: Eric from Cape York Connections - Thursday, Aug 30, 2007 at 20:13
Hang on I can hear it from here. LOL
All the best
Eric
259599
Follow Up By: Member - johnathon W (WA) - Friday, Aug 31, 2007 at 18:09
maybe that's just the old corgs in your head no pun intended mate good to see there are people out there that have a sense of humar
521200
