terrano bullbar
Submitted: Thursday, Aug 30, 2007 at 17:44
Member - goobot (cairns)
hey... does anybody know if a bullbar from another model vehicle will fit a nissan terrano
\having some trouble finding one to fit
have a top arvo
Reply By: Member - Julie P (VIC) - Thursday, Aug 30, 2007 at 19:26
Is it a Terrano II? Anyway try Eastcoast Bullbars in Qld - they do aftermarket for Terrano.
jules
259591
Follow Up By: Member - goobot (cairns) - Thursday, Aug 30, 2007 at 21:04
cheers julie will check that out
521094
Reply By: robak (QLD) - Friday, Aug 31, 2007 at 09:40
If it's a terrano I, then a pathfinder or navara bar will fit.
259674
Reply By: Member - Stephen M (NSW) - Friday, Aug 31, 2007 at 12:03
Dont know anything about terrano's only that there a Nissan but dont forget about airbag compatibility if you have one fitted. If you have airbag/s if taking from say a pathfinder or navara check this out first before purchasing the bar. Regards Steve M
259701
Follow Up By: Member - goobot (cairns) - Friday, Aug 31, 2007 at 15:37
hey steve ...i may seem stupid here
but how does that effect the bullbar decision
cheers mate
521188
Follow Up By: Member - Stephen M (NSW) - Friday, Aug 31, 2007 at 16:16
Hi there goobot, not real sure how the whole airbag system works but like my prado there are sensors behind the original factory bar (stickers visible) and by putting a non airbag compatible bullbar on a vehicle that has airbag/s could make the sensors not activate the airbags internally if your unfortunate enough that they need to deploy and stop your chest/head etc hitting the steering wheel. I would imagine it would be an insurance issue as
well in the event that you had to make a claim. I think for memory jeeps have a different set up and doesnt matter about airbag compatibility (first of the jeeps/wranglers with airbag/s ) There sensore are in the sills totally different system (only what Ive read).I know with my model prado there are some with airbags some with out and there are different bullbars to suit either, same with landcruisers. Hope this makes sense there is probably some one else who can fill you in more on the way the airbag system works. Regards Steve
521190
