Dust proofing Campervan
Submitted: Friday, Aug 31, 2007 at 14:36
Ianwa
Hi all,
I recently sold my trusty Maverick (years catching up with me faster than with the wagon) and bought a Ford Transit campervan - it has not been on a gravel road yet but, I have just seen one like
mine and it is covered in red dust inside - the owner is disgusted!!.
The back doors seem to be the problem - anybody had a similar problem and managed to solve it ?
Also any ideas on improving sound reduction in the front cabin area.?
Any advice/suggestions greatly appreciated.Thanks
Ian
Reply By: MEMBER - Darian (SA) - Friday, Aug 31, 2007 at 16:08
Yep - hate dust I do - dunno about the Transit types but all cars have this problem - the more 'shed-like' the rear profile, the worse probably. Air flowing over the shell creates a slight vacuum within. My habit is to check the door seals - clean them even with a damp cloth if required - then run your dash fan flat out (or as loud as you can stand) whenever you are on dirt - positive air pressure in the cab is the biggest tactic you can employ in my view. Leave the fan off, or worst still, leave a window down and it's curtains (of dust :-o).
259734
Reply By: Member - Paul P (QLD) - Friday, Aug 31, 2007 at 17:21
Hi Ianwa ,We have a Ford Transit Bus it travels 36 km's a day on gravel road and is full of dust, every 4 weeks we vacuum 1.2 kg's of dust up. I suggest you sell it.Ours has done 90000 km's and has five major breakdown's after all it's a FORD , FIX OR REPAIR DAILY. We are negotiating local council to buy back their dirt back.
259744
Reply By: Harry - Friday, Aug 31, 2007 at 19:43
Dust is probably coming in through the
water drain holes in the bottom of the doors.
I tape all but 1 up and stops most of the dust.
You might want to have made a rooftop dust deflector or they might even have that accessory.
Also look for missing rubber grommets at the bottom of the side panels behind the mudguards.
You'll have to get down underneath to look.
Ask your missus she might go down for you. :>))
259771
