GU Clutch replacement
Submitted: Monday, Sep 03, 2007 at 13:02
ThreadID: 49262 Views:2097 Replies:6 FollowUps:15
I am told the Patrol has a swicho 2 plate cluth that is horrendously expensive to replace and is often dispensed with in favour of a normal single plate arrangement, is this accurate? Any comments welcome.
Reply By: Bonz (Vic) - Monday, Sep 03, 2007 at 13:03
Thorry for the listhp I meant clutch, not cluth, what a clutz.
AnswerID: 260060
Follow Up By: Member - Ian W (NSW) - Monday, Sep 03, 2007 at 15:37
ROFLMAO
FollowupID: 521523
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Sep 03, 2007 at 16:19
The clutz was the Germananic version? Wot, are you pining for an auto boxed SUV now?
FollowupID: 521531
Follow Up By: Blaze - Monday, Sep 03, 2007 at 23:01
Bonz with all ure Money just put a Carbon Fibre one in with a Holinger H6S H-pattern 6-speed unit behind it.. LOL
FollowupID: 521594
Reply By: Batman69 - Monday, Sep 03, 2007 at 13:12
Bonz, Which GU are you referring to?
The 3.0lt TD has a dual mass flywheel which is very expensive, but TTBOMK they don't run with twin plate clutches.
OE clutches, pressure plates and flywheel kits are extremely expensive.
Aftermarket kits provide replacement solid mass flywheels that Nissan claim don't provide the vibration dampening of the dual mass flywheel and can lead to gearbox damage and NVH issues.
Hope this helps.
Steve
AnswerID: 260065
Follow Up By: Truckster (Vic) - Monday, Sep 03, 2007 at 13:24
too much red cordial for him... he does mean the grenade. Your rich bonz, stop playing games and fix it. Auto conversion is easy :D
FollowupID: 521511
Follow Up By: Member - 'Lucy' - Monday, Sep 03, 2007 at 19:03
Bonz
The make and model piece of Horth Chit that you refer to does indeed have a unique clutch assemply.
Because of the Dual mass flywheel thingy and price of same leading to owners ditching it for a cheaper item, and then suffering the dreaded shakes, the 'fitter and turners' of all things Nissan (ie fit it together and turn it into chit) decided to outsource a tender for a new age clutch.
They ended up with a single plasma, photon phaser operated thing that comes in a solid state form.
You would think it was gold plated and diamond studded from the price of the sucker, however it apparently outlasts the life of the vehicle.
If you contact Boba Fett motors in Tatooine they will give you a quote.
By the way are you doing the Alpine this year.
FollowupID: 521549
Follow Up By: Bonz (Vic) - Tuesday, Sep 04, 2007 at 00:31
may get there for a day Lucky but not without a clutch
FollowupID: 521609
Follow Up By: Member - 'Lucy' - Tuesday, Sep 04, 2007 at 03:21
How many days????
The full 4??
FollowupID: 521619
Follow Up By: Bonz (Vic) - Tuesday, Sep 04, 2007 at 06:37
nah one or two at the most, too much on at work!
FollowupID: 521626
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Sep 04, 2007 at 06:43
We can have a nurse standing by if you are going to do the changeover yourself mate. Sure the hammer will slip, or the screw driver, or the spanner or even just drop the gear box on a hand or something.
You may have noticed someone tried to call you......... Safe home coming mate.
FollowupID: 521627
Follow Up By: Bonz (Vic) - Tuesday, Sep 04, 2007 at 14:23
I have my own Nurse just in case, didnt notice a call but thats not surprising the phone is marginal over there
FollowupID: 521701
Reply By: Leroy - Monday, Sep 03, 2007 at 14:42
the 2.8 also has a dual mass flywheel. I know a mechanic who has one and had a vibration from new. When he replaced the clutch he also replaced the flywheel with a solid and he says the vehicle has never been smoother.
Leroy
AnswerID: 260089
Reply By: nowimnumberone - Monday, Sep 03, 2007 at 18:35
yep bonz there worth a lot
but the aftermarket flywheel arnt cheap either.
we did one last week and has now depeloved a vibration that can sometimes be caused by not using the duel mass one
AnswerID: 260127
Follow Up By: Bonz (Vic) - Tuesday, Sep 04, 2007 at 00:34
Mr PokemefingerwhereIshouldnt, do u have a rough idea of the comparative costs?
FollowupID: 521611
Follow Up By: nowimnumberone - Tuesday, Sep 04, 2007 at 20:53
ill let you know tommorow
FollowupID: 521771
Follow Up By: nowimnumberone - Wednesday, Sep 05, 2007 at 19:47
i spoke to paul today sirdidntyouoncepokeyourfingerwhereitaintmeanttogo.
he said give him a ring the price is to cheap to post
FollowupID: 521973
Reply By: Member - 'Lucy' - Monday, Sep 03, 2007 at 19:05
If you ask nicely, member Craizie will show you how to drive without a clutch as he is very experienced re same.
Two years ago Member Al and I escorted him all the way from broken Hill to Mt waverley without a clutch.
AnswerID: 260134
Reply By:- Monday, Sep 03, 2007 at 20:07
G'Dy Bonz,
Unlike many others I have changed the clutch to a heavy duty Exeddy and left the dual mass in place. I can give you the name / number of the mechanic if you like, he is close enough to you to visit
Rolande
AnswerID: 260153
Follow Up By: Bonz (Vic) - Tuesday, Sep 04, 2007 at 00:30
Yes please Rolande
FollowupID: 521608
Follow Up By:- Tuesday, Sep 04, 2007 at 18:40
G'Day Bonz,
Just email me for all the details
uhuforrest AT yahoo DOT com DOT au
Rolande
FollowupID: 521741
