Can the vehicle towing capcity be changed?
Submitted: Thursday, Sep 06, 2007 at 08:11
ThreadID: 49388 Views:5138 Replies:8 FollowUps:3
G'day All. The new hilux is only rated to tow 2250kg. Is it possible to have this upgraded by having modified suspension, or is as I suspect, more complex than that?
Reply By: Kev M (QLD Bound) - Thursday, Sep 06, 2007 at 08:23
Warren,
Check the article in 4WD Monthly September 2007 edition, article starts on page 101 and is very informative of increasing the load and towing capacities.
If needed I'll scan and email it to you if you want.
Cheers Kev
Russell Coight:
AnswerID: 260637
Follow Up By: Kev M (QLD Bound) - Thursday, Sep 06, 2007 at 09:16
For those who want to read the article
Sorry about the sizing still haven't worked that bit out
Cheers Kev
Russell Coight:
FollowupID: 522085
Follow Up By: Member - Douglas M (SA) - Thursday, Sep 06, 2007 at 10:31
Thanks for the article Kev. It is very informative and includes the legal bits about GVM. Keeping your mass at or below the legal GVM is difficult for us travellers. Very few suspension articles (including one on this site) mention the all important difficulty of legally increasing your GVM. Now that I know that it can be done on already registered vehicles I will be chasing it up.
Many Thanks
Doug
FollowupID: 522100
Follow Up By: Kev M (QLD Bound) - Thursday, Sep 06, 2007 at 10:52
No Problems Doug,
As I had mentioned earlier IMO it was one of the better written 4WD Journo articles of late. It assisted me in the decision making of getting a 100 Series chopped. I actually went and saw John Bourke about doing it. Just need to get one now and fit it into his time schedule as well as mine at this stage the earliest he could start is the 2nd week of October, which creates issues with going to Pyrenees with it.
Cheers Kev
Russell Coight:
FollowupID: 522105
Reply By: traveller2 - Thursday, Sep 06, 2007 at 08:24
Far more complex than that, usually related to the strength of the chassis/body, drivetrain, engine power and braking capacity.
All this is usually worked out by the manufacturer at the production stage. Another thing to take into account is the actual usage rating given in percentage of time at full GVM or towing capacity. The manufacturers rarely quote it and are even more reluctant to give it out.
Many would be surprised that the given tow capacity or GVM is not a continuous duty rating but usually a percentage of the total use time.
In simple terms if you run at GVM or full tow capacity most of the time you will wear your vehicle out quicker.
Rather than upgrading towing capacity or GVM I would be thinking of a larger vehicle that can do it easier rather than at the outer edge of the envelope.
Personally I prefer that the tare (unladen weight) of the towing vehicle comfortably exceed the GTM of the towed vehicle.
AnswerID: 260638
Reply By: Member - Norm C (QLD) - Thursday, Sep 06, 2007 at 09:27
Warren, while it is possible, I'd be a bit reluctant with the Hilux, particularly if you are on long range touring.
I have a new model ('05) Hilux TD manual. I've upgraded the suspension and have Firestone airbags on the rear leaf springs. Have also added a diesel power chip and 2.75 inch exhaust. We carry a heavy load (including boat) when touring and are a little over weight on GVM. Our CT is 1,500KG, so well under the limit. Our GCM is under the limit.
With the mods, the Hilux handles very well when touring, but:
I don't think the rear brakes are good enough for any more weight. You would need to upgrade them.
The clutch can't handle any more. Our biggest issue is getting going, particularly from a stand still up hill. The clutch has slipped a few times in this circumstance.
Apart from the clutch issue, the 3.0 TDs in the utes develop their power and torque fairly high in the rev range. When towing and load carrying, you need the torque down low to get you going. The power chip and exhaust have helped with this, but still an issue. See pic below for before and after power chip (but without exhaust).
We love our Hilux and it is a great touring vehicle, but I suspect we are operating it at it's limit. As a result, late next year I'm hoping to upgrade to a TD V8 70 series tray back. Bigger load carrying and tow capacity and torque available right across the rev range - in short an ideal towing and touring vehicle.Well if you forget about creature comforts and basic safety items like SRS and ABS it is, but that's another issue.
Norm C
!MPG:18!
AnswerID: 260649
Reply By: Redback - Thursday, Sep 06, 2007 at 09:35
My opinion would be to tow something lighter rather than tow something heavier, i'm always looking at lightening the load in my camper and 4b and my tow capacity is 3500kg with a max ball weight of 250kg.
Don't put more on your vehicle it only puts strain on it and makes going away a chore instead of being fun, remember it's the journey as well as the destination.
My camper is around 1,3tonne, weight over the hitch is 120kg.
Baz.
AnswerID: 260651
Reply By: Member - Doug T (Qld) - Thursday, Sep 06, 2007 at 09:41
Would it not be more sense to go and buy a bigger unit in the first place, like work out the specs of what your likely to want to do in the future and get an F250 or Dodge Ram instead of a Landcruiser or Nissan, that's called Planning aye.
AnswerID: 260653
Reply By: Member - Phil G (SA) - Thursday, Sep 06, 2007 at 14:24
Your main issue IMO is that you'll risk bending the chassis on a dual cab Hilux.
These vehicles can carry weight when its forward of the rear axle. But putting all the weight (especially a lot of drawbar weight) behind the rear axle can bend the chassis - especially for offroad travel.
Haven't seen it on a current series Hilux, but seen in on the previous model and other dual cabs.
AnswerID: 260707
Reply By: Motherhen - Thursday, Sep 06, 2007 at 23:55
As someone once said; modifying the tow tug is like putting a fire cracker on the tail of a donkey - it will go like the clappers for a little while, then stop. Get a horse that is capable of doing the job you want. Wise advice.
AnswerID: 260805
Reply By: Member - Warren R- Karratha WA - Friday, Sep 07, 2007 at 16:27
Thanks everyone for the informative & constructive input. It's so damn good to bounce these questions around and draw on all the experience and experiences out there. We are looking vans & campers, and although I was only going to nudge the limit on my towing capacity, you can bet your lefty there will always be something else I want to chuck on board. The Hilux has been a really good vehicle, but because of this lousy 2250kg limit, I'm now considering changing vehicles. Cheers, Waz
AnswerID: 260890
