Hot Water Services for Caravan
Submitted: Monday, Sep 10, 2007 at 21:59
ThreadID: 49539 Views:2814 Replies:6 FollowUps:0
Hi All,which caravanning forum do you find most helpful,i am looking to source a HWS that possibly could mount under cabinet so i can utilise the existing flick mixer that is in it,i dont really want to change the tap for one of those above sink instant units if i can avoid it.cheers Paul
Reply By: goldiedingdangdo - Monday, Sep 10, 2007 at 22:12
Best of luck but most possibilities need to be vented in at least some way. Sound as if you are after an internal fitting??
Ian
AnswerID: 261455
Reply By: dougie 41 - Tuesday, Sep 11, 2007 at 06:55
hi paul, Look at an Edson MP series. they are under sink units.
they are available in 9 or 30 litre models.
all the best Doug.
AnswerID: 261474
Reply By: Keith_A (Qld) - Tuesday, Sep 11, 2007 at 08:31
Hi TD - we have a Truma brand fitted on the shelf under the kitchen sink. 14 ltrs, Stainless Steel unit, insulated, automatic. We opted for gas only. They also make electric and gas/electric. Model is B14.
They are a German company - founded in 1949.
Widely available from major RV outlets in Aust. The Australian agent is Dometic in Melbourne (03 9545 5655)
They require 2 vents to the outside - one for the gas flue and a second - perhaps to allow air to circulate. There are also two drain pipes - one on the cold water inlet exits through the floor, plus a Safety pressure relief on the hot water outlet.
Size - aprox 350x350 x 320; external vents 130x240.
They also make a smaller 10 Ltr model B10.
................Keith
AnswerID: 261500
Reply By: Member Boroma 604 - Tuesday, Sep 11, 2007 at 09:24
Gooday,
Amother vote for Truma, S/Steel tank, no anode to worry about hot enough to shower in about 10 minutes on either Gas or 240v, you can run them both together if you wiah to get it hot quicker.
Like everything for caravans they are not cheap but good gear.
Cheers Boroma604.
AnswerID: 261512
Reply By: Member Boroma 604 - Tuesday, Sep 11, 2007 at 09:25
Gooday,
Cheers Boroma604.
AnswerID: 261513
Reply By: AndrewX - Tuesday, Sep 11, 2007 at 23:21
Try to get 240v and gas. Have friends with gas only and it uses lots of gas. Have other friends with 240v only and off road they have cold water. I'm getting a dual unit - costs a bit more but want the flexibility.
AnswerID: 261649
