Drawer Slides for hilux
Submitted: Wednesday, Sep 12, 2007 at 22:12
ThreadID: 49604 Views:3967 Replies:5 FollowUps:3
I want to build some _Affordable_Storage_Drawers.aspx to go in the back of my hilux. I already have a fridge mounted so the _Affordable_Storage_Drawers.aspx will be 1100mm long by 710mm wide. I plan to have the _Affordable_Storage_Drawers.aspx made up out of sheet metal. My problem is that the only slides I can find are 750 long. Does anyone know where I can get some slides that are about 1m long?
Reply By: Shaker - Wednesday, Sep 12, 2007 at 23:10
You can get them here:
Häfele Australia Pty. Ltd.
8 Monterey Road
Dandenong, Victoria, 3175
AnswerID: 261813
Follow Up By: Shaker - Wednesday, Sep 12, 2007 at 23:11
The accent over the 'a' must have affected the c & p
It is Hafele Australia Pty Ltd.
FollowupID: 523258
Follow Up By: Shaker - Wednesday, Sep 12, 2007 at 23:17
Or herehttp://www.rockler.com/product.cfm?page=1491
or Google!
FollowupID: 523259
Follow Up By: Tim&Di - Thursday, Sep 13, 2007 at 07:58
Thanks, I found some on Hafele that have a 1000mm extension with a 200kg load limit - will price them today, expect they won't be cheap. The single extension are 1000 long with about 850 extension - will price these also but it means that i will have 250mm of the drawer not exposed which isn't the best when they are 710 wide.
FollowupID: 523276
Reply By: Matt(WA) - Thursday, Sep 13, 2007 at 00:07
Hi Tim,
Try Galvins
MZRHD1000 HEAVY DUTY RUNNER ZP 030285 1000MM
I used the 800mm one's(I think) for my home made fridge slide, there are photo's of it in my pictures
Hope this helps
Matt
AnswerID: 261819
Reply By: yowie - Thursday, Sep 13, 2007 at 05:30
I also used the Hafele runners.
http://www.hafele.com.au/isapi/online/catalogues/tchff07/forGuests/index.html
AnswerID: 261824
Reply By: Member - Phil G (SA) - Thursday, Sep 13, 2007 at 07:51
Depends on the runners.
You need to check how far they come out.
A 750mm single throw runner will only come out about 550-600mm.
While a double throw runner will come out the full length of the runner.
I use the 600mm double throw Hafele runners and they come out the full 600mm. I use the same runners on a couple of 900mm _Affordable_Storage_Drawers.aspx and its no big deal that they don't come out full length.
AnswerID: 261837
Reply By: jdbb - Thursday, Sep 13, 2007 at 16:53
I used the 1000 and 900 hafele runners on my drawer system. They worked well. Just note that I think they only take 100kg per pair - not 200kg. Cost about $70 per pair.
AnswerID: 261922
