crank batteries
Submitted: Sunday, Sep 16, 2007 at 14:06
Member - Smithy (VIC)
G’day folks
Just a quickie, I need a new crank battery for a 4.2TD patrol after doing a search here and on the net I would still like to know what others are using
At this stage I think I will stick to the wet cell variety any comments most welcome
Reply By: MEMBER - Darian (SA) - Sunday, Sep 16, 2007 at 14:52
Yuasa Overlander - 700 CCA (many makes are commonly 600CCA).
3 years old - has done quite a bit of rough outback travel - still good.
262475
Reply By: Member - John - Sunday, Sep 16, 2007 at 17:21
Smithy, I am using AC Delco Calcium 730 cca very very good, $150.00. Maintenance free and still wet cell. John
262496
Reply By: Member - John - Sunday, Sep 16, 2007 at 17:22
Bugger, the number for the AC Delco is S95D31 LHD or RHD, which ever side your battery is on.
262497
Reply By: Member - Doug T (Qld) - Sunday, Sep 16, 2007 at 19:22
I reackon these are spot on, not cheap but will last and will do the job. check the Red Top
Battery
262537
Reply By: Member - Roachie (SA) - Sunday, Sep 16, 2007 at 19:27
You'll get as many different opinions to this question as there are batteries on the market.
In my case I've been using 4 Super Charge Gold Series for a few years now. These have 760CCA, which is the highest rating I've seen ina standard size casing. They are a maintenance free type of battery.
I've had a pair of them in my camper trailer for about 3 years now and also have 2 in the Patrol, joined permanently as starter batteries for the Chev.
Roachie
262538
Reply By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 20:37
After having had a sealed calcium battery spill it's guts all down the left side of my engine bay I will be sticking with wet lead acid now. I now have an Exide extreme.
262552
Reply By: Member - Smithy (VIC) - Monday, Sep 17, 2007 at 08:49
Thanks for the replies, it gives me other options to consider
262616
Reply By: Member - Smithy (VIC) - Monday, Sep 17, 2007 at 16:50
Well after chasing around a few battery suppliers ended up with a
Acdelco 730 CCA will see how it performs
And BTW try not to break the Nissan + terminal connector was told it had to come from Japan, nearly fell over when parts bloke told me the price, around a $140 comes with the cable to starter motor
And thanks for your replies once again
262693
