Dual Batteries
Submitted: Monday, Sep 17, 2007 at 09:52
Grassparrot
I have a new Triton Dual Cab and wish to locate a second battery at the rear of the vehicle to run my Waeco 80L fridge only. I intend to use a 100ah AGM. For charging can I run a wire direct from the alternator to the proposed AGM? If so, how thick should the wire be to get as quicker charge as possible and do I need a fuse or any other safety devices? Trying to do it as cheaply and simply as possible. I only drive the vehicle for 40 minutes per day.
Reply By: Member - Doug T (Qld) - Monday, Sep 17, 2007 at 10:41
Mr 28
If you only drive for 40 minutes each day why do need a 80lt fridge,
For the electrical question what I would do , [ and my methods are always different to what an Auto sparky would do but it works ] is just run a heavy duty wire from the Pos' terminal of the main Battery to the + of the 2nd battery , and a earth from the Neg' terminal to the body of the vehicle, then connect the fridge as normal to an Anderson Plug fitted to the body which would be connected to the battery, It will still get charged , I would also use a Deep Cycle Optima Yellow Top Battery,
If you wanted to add an Isolator Switch kit, you could wire that in following the instructions that would come with it, that could be obtained from TJM or ARB,
Some might ask why Optima, answer is I believe them to be reliable and
mine has not faulted in 3 years, also vibration resistant.
Doug
262640
Follow Up By: Grassparrot - Monday, Sep 17, 2007 at 11:34
Would this drain the vehicles main battery as it is connected all the time and the fridge runs constantly? I have a large fridge for
camping as I have 3 kids. Fridge is used daily as an esky for drinks and the missus going shopping.
524120
Follow Up By: Member - Doug T (Qld) - Monday, Sep 17, 2007 at 11:48
In that case then you should get the Isolator Kit. have a browse in this
DUAL BATTERY SYSTEMS
524126
Follow Up By: TD100 - Monday, Sep 17, 2007 at 19:20
Dont worry Doug,i get asked all the time why i use optimas(2 of in 100s T/D)as main batteries @4.5 years old with no problems to speak of.i also believe these to be an excellent choice in batteries.cheers Paul
524216
