wiring 7 pin trailer plug wots 1-7?
Submitted: Monday, May 19, 2003 at 17:25
Ellis - NT
gday all
just wondering if anyone can tell me what the numbering code is
ie 1 is indicator etc etc
7 is earth
any help would be much app by this bodgy backyarder!
Thanx in advance, Ellis
Reply By: GOB vic - Monday, May 19, 2003 at 17:38
ellis your lucky ifound the sheet
1 left indicator yellow
2 aux blue
3 earth white
4 right ind green
5 aux black
6 stop red
7 tail brown
the 2 aux are normally trailrer brakes and 12v supply to a van if towing89 nissan looking foward to august and more travelling
20433
Reply By: Kev - (Cairns,QLD) - Monday, May 19, 2003 at 17:45
If you don't mind me asking , is Ellis your first name or your last ?
Do you live in
Darwin ?
Kev.
20437
Follow Up By: Ellis - NT - Monday, May 19, 2003 at 23:36
Ellis is my middle name & I'm in Alice.
Thanks Gob 4 looking up the sheet. I had the towbar fitted when I was rear ended. The insurors saw sense as the TJM step-tow was the same price as the Toyota flimsy step. As such the wiring was never done & has been at the bottom of a ong list.
Any way hanks again.
Ellis
13139
Reply By: Member - Rohan K - Tuesday, May 20, 2003 at 11:09
Ellis, it would appear not all 7 pins are wired the same way. My connections are different from those given above, as are the wire colours. I suggest you break-out the trusty multi-metre to check yours.Be good, or be quick.
Rohan (
Sydney)
20520
Reply By: Member - Mal - Tuesday, May 20, 2003 at 12:50
Ellis,
The "Vehicle Standards Bulletin" issued by the Commonwealth Department of Transport states "Trailers and towing vehicles must have electrical connectors which comply with Australian Standard2513-1982 'Electrical Conectors forTrailer Vehicles'.
1 Left hand turn Yellow
2 Reversing signal Black
3 Earth return White
4 Right hand turn Green
5 Service brakes Blue
6 Stop lamps Red
7 Rear lamps, clearence and side marker lamps Brown
.........and for 12 pin connectors
8 Battery charger / electric winch
Orange
9 Auxiliaries, etc/Battery feed Pink
10 Earth return White
11 Rear fog lamp
Grey
12 Spare Violet
Mal T
20530
Follow Up By: Member - Rohan K - Wednesday, May 21, 2003 at 10:47
Thanks Mal. I'll take this to my sparkie and ask why he didn't follow convention.Be good, or be quick.
Rohan (
Sydney)
13271
